New advances to prepare GYSELA-X code for exascale global gyrokinetic plasma turbulence simulations: porting on GPU and ARM architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
J Bigot
  • Fonction : Auteur
J Dechard
  • Fonction : Auteur
2022-06-27_PASC_VGrandgirard_vfinal.pdf (2.99 Mo) Télécharger le fichier
cea-03740685 , version 1 (29-07-2022)
  • HAL Id : cea-03740685 , version 1
Virginie Grandgirard, Kevin Obrejan, Dorian Midou, Y Asahi, P-E Bernard, et al.. New advances to prepare GYSELA-X code for exascale global gyrokinetic plasma turbulence simulations: porting on GPU and ARM architectures. PASC22 - Conderence on The Platform for Advanced Scientific Computing, the Association for Computing Machinery (ACM); the Swiss National Supercomputing Centre (CSCS), Jun 2022, Bâle (virtual event), Switzerland. pp.1-21. ⟨cea-03740685⟩
141 Consultations
228 Téléchargements
