M. Ait-ahmed, Contribution à la modélisation géométrique et dynamique des robots parallèles, Ait Mohamed A, 1993.
M. J. Aldon, Elaboration automatique de modèles dynamiques de robots en vue de leur conception et de leur commande, 1982.
M. J. Aldon, Identification des paramètres structuraux des robots manipulateurs, Proc. Outils Mathématiques pour la Modélisation et la Commande des Robots, pp.243-296, 1986.
C. H. An, C. G. Atkeson, and J. M. Hollerbach, Estimation of inertial parameters of rigid body links of manipulators, Proc. 24 th IEEE Conf. on Decision and Control, pp.990-995, 1985.
C. H. An and J. M. Hollerbach, Kinematic stability issues in force control of manipulators, Proc. IEEE Int. Conf. on Robotics and Automation, pp.897-903, 1987.
A. J. Gosselin and C. , Détermination du degré de liberté des chaînes cinématiques, Trans. of the CSME, vol.12, pp.219-226, 1977.
A. J. , Fundamentals of Robotic Mechanical Systems, 2002.
S. Arimoto and F. Miyazaki, Stability and robustness of PID feedback control for robots manipulators of sensory capability, The 1 st Int. Symp. of Robotics Research, 1984.
S. Arimoto, Y. H. Liu, and T. Naniwa, Model-based adaptive hybrid control for geometrically constrained robots, Proc. IEEE Int. Conf. on Robotics and Automation, pp.618-623, 1993.
W. W. Armstrong, Recursive solution to the equation of motion of an Nlinks manipulator, Proc. 5 th World Congress on Theory of Machines and Mechanisms, pp.1343-1346, 1979.
S. Automation and . Francisco, , pp.510-518, 1986.
B. Armstrong, Dynamics for robot control: friction modeling and ensuring excitation during parameter identification, 1988.
B. Armstong, On finding exciting trajectories for identification experiments involving systems with non linear dynamics, The Int. J. of Robotics Research, vol.89, issue.6, pp.28-48, 1989.
B. Armstrong, Control of Machines with frictions, 1991.
B. Armstrong-hélouvry, P. Dupont, and C. Canudas-de-wit, A survey of analysis tools and compensation methods for the control of machines with friction, Automatica, vol.30, issue.10, pp.1083-1138, 1994.
H. Asada and J. E. Slotine, Robot analysis and control, 1986.
C. G. Atkeson, C. H. An, and J. M. Hollerbach, Estimation of inertial parameters of manipulator loads and links, The Int. J. of Robotics Research, vol.5, issue.3, pp.101-119, 1986.
A. Aubin, Modélisation, identification et commande du bras manipulateur TAM, INPG, 1991.
J. Baillieul, J. M. Hollerbach, and R. Brockett, Programming and control of kinematically redundant manipulators, Proc. 23 rd IEEE Conf. on Decision and Control, pp.768-774
J. Baillieul and J. Baillieul, Kinematic programming alternatives for redundant manipulators, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1698-1704, 1985.
L. Baron and J. Angeles, The decoupling of the direct kinematics of parallel manipulators using redundant sensors, Proc. IEEE Int. Conf. on Robotics and Automation, pp.974-979, 1994.
R. H. Bartels, J. C. Beaty, and B. A. Barsky, Mathématiques et CAO 6, B-splines, 1988.
J. Baumgarte, Stabilization of constraints and integral of motion, Computer Methods in Applied Mech. Eng, vol.1, issue.1, pp.1-16, 1972.
D. Bayard and J. T. Wen, New class of control laws for robotic manipulators; Part 2: Adaptive case, NASA Technical Memorandum, vol.47, issue.5, pp.33-669, 1974.
A. K. Bejczy, A. K. Bejczy, T. J. Tarn, X. Yun, and S. Hans, Non linear feedback control of Puma 560 robot arm by computer, Tutorial Workshop, 18 th IEEE Conf. on Decision and Control, pp.1680-1688, 1979.
L. Beji, Modélisation, identification et commande d'un robot parallèle, 1997.
A. Bennallegue, Contribution à la commande dynamique adaptative des robots manipulateurs rapides, 1991.
S. Benhlima, Identification des paramètres dynamiques des systèmes mécaniques articulés complexes, 1993.
G. T. Bennett, A new mechanism, Engineering, vol.76, pp.777-778, 1903.
F. E. Bennis, . Nantes, ;. France, F. Bennis, and W. Khalil, Contribution à la modélisation géométrique et dynamique des robots à chaîne simple et complexe, IEEE Trans. on Systems, Man, and Cybernetics, vol.21, issue.2, pp.318-326, 1991.
F. Bennis and W. Khalil, Modèle géométrique inverse des robots à chaîne découplable : application aux équations de contraintes des boucles fermées, Trans. of the Canadian Society for Mechanical Engineering, vol.17, issue.4A, pp.473-491, 1993.
M. Benoit, M. Briot, H. Donnarel, A. Liégeois, M. A. Meyer et al., Synthèse de la commande dynamique d'un téléopérateur redondant, pp.89-103, 1975.
H. Berghuis, S. Bhattacharya, H. Hatwal, G. A. Bhattacharya, S. Nenchev et al., An on-line estimation scheme for generalized Stewart platform type parallel manipulators, Model-based robot control: from theory to practice, vol.32, pp.957-964, 1993.
R. Bernhardt and S. L. Albright, Robot calibration, 1993.
S. Besnard and W. Khalil, Calibration of parallel robots using two inclinometers, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1758-1763, 1999.
S. Besnard, Etalonnage géométrique des robots série et parallèles, 1996.
S. Besnard, W. Khalil, and A. Bicchi, Identifiable parameters for parallel robots kinematic calibration, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1038-1044, 1998.
URL : https://hal.archives-ouvertes.fr/hal-00401752
T. O. Binford, Exploratory study of computer integrated assembly system, Stanford Artificial Intelligence Lab, 1977.
J. Blanchon, Génération et identification des lois de mouvement en robotique : application à l'identification et à la correction de trajectoires du manipulateur PUMA 560, USTL, 1987.
, Modeling, identification and control of robots
J. H. Borm and C. H. Menq, Determination of optimal measurement configurations for robot calibration based on observability measure, The Int. J. of Robotics Research, vol.10, issue.1, pp.51-63, 1991.
P. Borrel and P. Borrel, Contribution à la modélisation géométrique des robotsmanipulateurs ; application à la conception assistée par ordinateur, USTL, 1979.
T. L. Boullion, P. L. Odell, and B. Bouzouia, Commande des robots manipulateurs : identification des paramètres et étude des stratégies adaptatives, UPS, 1971.
F. Boyer, Contribution à la modélisation et à la commande dynamique des robots flexible, 1994.
F. Boyer and W. Khalil, An efficient calculation of flexible manipulator inverse dynamics, The Int. J. of Robotics Research, vol.17, issue.3, pp.282-293, 1998.
URL : https://hal.archives-ouvertes.fr/hal-00629447
F. Boyer, M. Porez, and W. Khalil, Macro-continuous Computed Torque Algorithm for a three-dimensional Eel-Like Robot, IEEE Transaction, Robotics, vol.22, issue.4, pp.763-775, 2006.
URL : https://hal.archives-ouvertes.fr/hal-00630750
H. Brandl, R. Johanni, and M. Otter, A very efficient algorithm for the simulation of robots and multibody systems without inversion of the mass matrix, Proc. IFAC Symp. on Theory of Robots, pp.365-370, 1986.
B. Brogliato and H. Bruyninckx, Closed-form forward position kinematics for a (3-1-1-1) 2 fully parallel manipulator, IEEE Trans. on Robotics and Automation, vol.14, issue.2, pp.326-328, 1991.
J. W. Burdick, An algorithm for generation of efficient manipulator dynamic equations, Proc. IEEE Int. Conf. on Robotics and Automation, pp.212-218, 1986.
J. W. Burdick, Kinematic analysis and design of redundant manipulators, 1988.
J. Caenen, Contribution à l'identification de paramètres géométriques et non géométriques d'un modèle de robot. Application à l'amélioration de la précision de positionnement statique, 1993.
H. Cannon, E. Schmitz, C. Canudas-de-wit, P. Noël, A. Aubin et al., Adaptive Friction compensation in robot manipulators: low-velocities, Proc. IEEE Int. Conf. on Robotics and Automation, vol.3, pp.1383-1389, 1984.
W. C. Canudas-de, N. Fixot, and K. J. Aström, Trajectory tracking in robot manipulators via nonlinear estimated feedback, IEEE Trans. on Robotics and Automation, vol.8, issue.1, pp.138-144, 1992.
R. H. Castain, R. P. Paul, M. Carricato, and C. Gosselin, On the modeling of leg constraints in the dynamic analysis of Gough/Stewart-type platforms, ASME Journal of Computational and Nonlinear Dynamics, vol.3, issue.1, pp.68-72, 1984.
J. M. Castelain, Application de la méthode hypercomplexe aux modélisations géométriques et différentielles des robots constitués d'une chaîne cinématique simple, 1986.
G. Cesareo, F. Nicolo, and S. Nicosia, DYMIR: a code for generating dynamic model of robots, Proc. IEEE Int. Conf. on Robotics, pp.115-120, 1984.
M. A. Chace, Analysis of the time dependance of multi-freedoom mechanical system in relative coordinate, Trans. of ASME, J. of Engineering for Industry, vol.89, pp.119-125, 1967.
M. A. Chace and Y. O. Bayazitoglu, Development and application of a generalized d'Alembert force for multi-freedom mechanical system, Trans. ASME, J. of Engineering for Industry, vol.93, pp.317-327, 1971.
S. Chand and K. L. Doty, On-line polynomial trajectories for robot manipulators, The Int. J. of Robotics Research, vol.4, issue.2, pp.38-48, 1985.
P. H. Chang, A closed form solution for the control of manipulators with kinematic redundancy, Proc. IEEE Int. Conf. on Robotics and Automation, pp.9-14, 1986.
S. Charentus and P. A. Chebychev, Modélisation et commande d'un robot manipulateur redondant composé de plusieurs plates-formes de Stewart, Mémoires presentées à l'Académie imperial des sciences de Saint-Pétersbourg par divers savants, p.1854, 1990.
P. Chedmail, M. Gautier, and W. Khalil, Automatic modelling of robots including parameters of links and actuators, Proc. IFAC Symp. on Theory of Robots, pp.295-299
DOI : 10.1016/s1474-6670(17)59458-6
P. Chedmail, P. Chedmail, and M. Gautier, Contribution à la conception des robots et à la modélisation et commande de robots souples, Trans. of ASME, J. of Engineering for Industry, vol.112, issue.4, pp.361-367, 1990.
P. Modeling-;-chedmail and E. Dombre, CAO et robotique : conception et programmation des cellules robotisées, Productique Appliquées, vol.5, issue.2, pp.27-38, 1992.
P. Chedmail, E. Dombre, P. Wenger, C. La, and . Robotique, outils et méthodologies, Collection 'Etudes en Mécanique des Matériaux et des Structures', Hermès, 1998.
K. C. Cheok, J. L. Overholt, and R. R. Beck, Exact methods for determining the kinematics of a Stewart platform using additional displacement sensors, J. of Robotic Systems, vol.10, issue.5, pp.974-979, 1993.
C. Cherki-b-;-chevallereau and W. Khalil, Efficient method for the calculation of the pseudo inverse kinematic problem, Commande des robots manipulateurs par retour d'état estimé, pp.1842-1848, 1987.
C. Chevallereau and C. Chevallereau, Feasible trajectories in task space from a singularity for a non redundant or redundant robot manipulator, Contribution à la commande des robots-manipulateurs dans l'espace opérationnel, vol.17, pp.56-69, 1988.
S. Chiaverini and L. Sciavicco, The parallel approach to force/position control of robotic manipulators, Chiaverini 93, vol.9, pp.361-373, 1993.
R. Clavel, Une nouvelle structure de manipulateur parallèle pour la robotique légère, Revue APII-AFCET, vol.23, pp.501-519, 1989.
B. P. Cloutier, D. K. Pai, and U. M. Ascher, The formulation stiffness of forward dynamics algorithms and implications for robot simulation, Proc. IEEE Int. Conf. on Robotics and Automation, pp.2816-2822, 1995.
A. Codourey and B. E. , A body oriented method for finding a linear form of the dynamic equatiojns of fully parallel robot, IEEE Conf. on Robotics and Automation, pp.1612-1619, 1997.
P. Coiffet, Les Robots ; Tome 1 : Modélisation et commande, Hermès, 1981.
R. Colbaugh, H. Seraji, and K. Glass, Direct adaptive impedance control of robot manipulators, J. of Robotic Systems, vol.10, pp.217-248, 1993.
DOI : 10.1002/rob.4620100205
P. Corke, In situ measurement of robot motor electrical constants, Robotica, vol.23, issue.14, pp.433-436, 1996.
J. J. Craig, Introduction to robotics: mechanics and control, 1986.
J. J. Craig, P. Hsu, and S. Sastry, Adaptive control of mechanical manipulators, Proc. IEEE Int. Conf. on Robotics and Automation, pp.190-195, 1986.
DOI : 10.1109/robot.1986.1087661
J. J. Craig, Calibration of industrial robots, Proc. 24th Int. Symp. on Industrial Robots, pp.889-893, 1993.
E. Dafaoui, Modélisation et commande d'un robot parallèle : application au suivi de contour, 1994.
D. El, -. M. Amirat, Y. Pontnau, J. François, and C. , Analysis and Design of a Six-DOF Parallel Manipulator, Modeling, Singular Configurations, and Workspace, IEEE Trans. on Robotics and Automation, vol.14, issue.1, pp.78-92, 1998.
P. R. Dahl, Measurements of solid friction parameters of ball bearings, Proc. of the 6 th Annual Symp. on Incremental Motion Control Systems and Devices, 1977.
M. Damak, E. Thèse-de-doctorat, . Lille, B. France-;-dasgupta, T. S. Mruthyunjaya et al., A general strategy based on the Newton-Euler approach for the dynamic formulation of parallel manipulators, Théorie et instrumentation pour l'étalonnage statique des robots : vers une programmation hors-ligne industriellement plus efficace, vol.33, pp.801-824, 1996.
D. Daney, Etalonnage géométrique des robots parallèles, 2000.
C. De-boor, A practical guide to splines, 1978.
E. Dégoulange, Commande en effort d'un robot manipulateur à deux bras : application au contrôle de la déformation d'une chaîne cinématique fermée, 1993.
P. De-larminat and Y. Thomas, Automatique des systèmes linéaires ; Tome 2 : Identification, Editions Flammarion, Larminat, 1977.
S. Delignières, Choix de morphologies de robot, ENSM, 1987.
A. Luca-91a]-de-luca and G. Oriolo, Issues in acceleration resolution of robot redundancy, Proc. IFAC Symp. on Robot Control, SYROCO'91, pp.665-670, 1991.
. Luca, A. De-luca, and C. Manes, Hybrid force-position control for robots in contact with dynamic environments, Proc. IFAC Symp. on Robot Control, SYROCO'91, pp.177-182, 1991.
J. Denavit and R. S. Hartenberg, A kinematic notation for lower pair mechanism based on matrices, Trans. of ASME, J. of Applied Mechanics, vol.22, pp.215-221, 1955.
P. Desbats, Modélisation et commande dynamique des robots rapides, 1990.
J. Modeling-;-de-schutter and H. Van-brussel, Compliant robot motion -II -a control approach based on external control loop, The Int. J. of Robotics Research, vol.7, issue.4, pp.18-33, 1988.
C. A. Desoer and M. Vidyaasagar, Feedback systems: input-output properties, 1975.
P. Deitmaier, The Stewart-Gough platform of general geometry can have 40 real postures, Advances in Robot Kinematics: Analysis and Control, pp.7-16, 1998.
S. R. Dillon, Computer assisted equation generation in linkage dynamics, 1973.
E. Dombre, Analyse des performances des robots-manipulateurs flexibles et redondants ; contribution à leur modélisation et à leur commande, 1981.
E. Dombre, P. Borrel, and A. Liégeois, A CAD system for programming and simulating robot's actions, Computing Techniques for Robots, pp.222-247, 1985.
E. Dombre and W. Khalil, Modélisation et commande des robots, Hermès, 1988.
E. Dombre, Outils d'aide à la conception de cellules robotisées, Techniques de la robotique : perception et planification, Hermès, pp.255-291, 1988.
E. Dombre and A. Fournier, Yet another calibration technique to reduce the gap between CAD world and real world, Proc. 1 st WAC'94 on Intelligent Automation and Soft Computing, pp.47-52, 1994.
E. Dombre and W. Khalil, Robot manipulators: Modeling, Performace Analysis and Control, ISTE, 2007.
J. J. Dongarra, C. B. Moler, J. R. Bunch, and G. W. Stewart, LINPACK User's Guide, 1979.
M. Douss, Programmation hors ligne par CAO-Robotique : caractérisation de lois de contrôleurs de robots et étalonnage de cellules robotisées en vue d'améliorer la précision, 1996.
S. H. Drake, Using compliance in lieu of sensory feedback for automatic assembly, Dept. of Mechanical Engineering, 1977.
M. R. Driels, U. S. Pathre, S. Dubowsky, and D. T. Des-forges, Significance of observation strategy on the design of robot calibration experiment, Trans. of ASME, J. of Dynamic Systems, Measurement, and Control, vol.7, pp.193-200, 1979.
J. Duffy, The fallacy of modern hybrid control theory that is based on 'orthogonal complements' of twist and wrench spaces, J. of Robotic Systems, vol.7, pp.139-144, 1990.
C. W. Edwall, H. J. Pottinger, and C. Y. Ho, Trajectory generation and control of a robot arm using spline functions, Proc. Robot-6, pp.421-444, 1982.
O. Egeland and I. Spangelo, Manipulator control in singular configurationsMotion in degenerate directions, Advanced Robot Control, pp.296-306, 1991.
E. Omri and J. , Analyse géométrique et cinématique des mécanismes de type manipulateur, 1996.
E. Serafi, K. Serafi, and W. Khalil, Contribution à la commande adaptative des robots manipulateurs, Proc. IEEE Int. Conf. on Robotics and Automation, pp.2142-2147, 1991.
E. L. Suryohadiprojo and A. H. , A study of kinematic models for forward calibration of manipulators, Proc. IEEE Int. Conf. on Robotics and Automation, pp.798-800, 1988.
L. J. Everett, Forward calibration of closed loop jointed manipulators, The Int. J. of Robotics Research, vol.8, issue.4, pp.85-91, 1989.
P. Eykhoff, System identification: parameter and state estimation, 1974.
G. Fages and R. Featherstone, Position and velocity transformations between robot end-effector coordinates and joint angles, The Int. J. of Robotics Research, vol.21, issue.2, pp.35-45, 1983.
R. Featherstone, The calculation of robot dynamics using articulatedbody inertias, The Int. J. of Robotics Research, vol.2, issue.3, pp.87-101, 1983.
E. P. Ferreira, Contribution à l'identification de paramètres et à la commande des robots manipulateurs, 1984.
E. F. Fichter, A Stewart platform-based manipulator: general theory and practical construction, The Int. J. of Robotic Research, vol.5, issue.2, pp.157-181, 1986.
W. Fisher and M. S. Mujtaba, Hybrid position / force control: a correct formulation, The Int. J. of Robotics Research, vol.11, issue.4, pp.299-311, 1992.
M. Fliess, J. Lévine, P. Martin, P. Rouchon, G. E. Forsythe et al., Flatness and defect of nonlinear systems: introductory theory and examples, Computer methods for mathematical computations, vol.61, pp.1327-1361, 1977.
A. Fournier, Génération de mouvements en robotique ; application des inverses généralisées et des pseudo-inverses, 1980.
J. Fourquet, L. B. Freidovich, and A. A. Pervozvanski, Mouvement en temps minimal pour les robots manipulateurs en tenant compte de leur dynamique, Proc. IFAC Symp. on Robot Control, SYROCO'97, pp.85-90, 1990.
E. Freund, Fast nonlinear control with arbitrary pole placement for industrial robots and manipulators, The Int. J. of Robotics Research, vol.1, issue.1, pp.65-78, 1982.
;. Modeling and C. Froissart, Génération adaptative de mouvement pour processus continus
. Fu-s, Y. Yao, and Y. Wu, Comments on ''A Newton-Euler formulation for the inverse dynamics of the Stewart platform manipulator, Mech. Mach. Theory, vol.33, pp.1668-1671, 1998.
H. Gaudin, Contribution à l'identification in situ des constantes d'inertie et des lois de frottement articulaire d'un robot manipulateur en vue d'une application expérimentale au suivi de trajectoires optimales, 1992.
M. Gautier, Identification of robots dynamics, Proc. IFAC Symp. on Theory of Robots, pp.351-356, 1986.
URL : https://hal.archives-ouvertes.fr/hal-00402723
M. Gautier and W. Khalil, On the identification of the inertial parameters of robots, Proc. 27 th IEEE Conf. on Decision and Control, pp.2264-2269, 1988.
M. Gautier, Contribution à la modélisation et à l'identification des robots, Etat, ENSM, 1990.
M. Gautier and W. Khalil, Direct calculation of minimum set of inertial parameters of serial robots, IEEE Trans. on Robotics and Automation, vol.6, issue.3, pp.368-373, 1990.
M. Gautier, Numerical calculation of the base inertial parameters, J. of Robotic Systems, vol.8, issue.4, pp.485-506, 1991.
M. Gautier and W. Khalil, Exciting trajectories for inertial parameters identification, The Int. J. of Robotics Research, vol.11, issue.4, pp.362-375, 1992.
M. Gautier, Optimal motion planning for robot's inertial parameters identification, Proc. 31 st IEEE Conf. on Decision and Control, vol.1, pp.70-73, 1992.
M. Gautier, C. Janin, and C. Pressé, On the validation of robot dynamic model, Proc. 2 nd European Control Conf., ECC'93, pp.2291-2295, 1993.
M. Gautier, P. Vandanjon, and C. Pressé, Identification of inertial and drive gain parameters of robots, Proc. IEEE 33 th Conf. on Decision and Control, pp.3764-3769, 1994.
M. Gautier, W. Khalil, and P. P. Restrepo, Identification of the dynamic parameters of a closed loop robot, Proc. IEEE Int. Conf. on Robotics and Automation, pp.3045-3050, 1995.
M. Gautier, A comparison of filtered models for dynamic identification of robots, Proc. IEEE 35 th Conf. on Decision and Control, pp.875-880, 1996.
M. Gautier-m-;-gautier, W. Khalil, E. Dombre, ;. M. Paris, S. Gautier et al., Etude et conception de la commande en effort d'un télémanipulateur équipé d'un capteur d'effort à sa base et son extrémité, Proc. Int. Conf. on Robotics and Automation, vol.9, pp.237-254, 1992.
M. Giordano, G. Gogu, A. A. Goldenberg, B. Benhabib, and R. G. Fenton, A complete generalized solution to inverse kinematics of robots, Proc.16 th Int. Symp. on Industrial Robots, Bruxelles, vol.1, pp.14-20, 1985.
G. H. Golub and C. F. Van-loan, Matrix computations, 1983.
B. Gorla, M. Renaud, C. Gosselin, C. Gosselin, and J. Angeles, Kinematic analysis, optimization and programming of parallel robotic manipulators, IEEE Trans. on Robotics and Automation, vol.6, issue.3, pp.281-290, 1984.
C. M. Gosselin, Parallel computationnal algorithms for the kinematics and dynamics of parallel manipulators, IEEE Int. Conf. on Robotics and Automation, vol.1, pp.883-889, 1993.
A. Goswami, A. Quaid, and M. Peshkin, Identifying robot parameters using partial pose information, Proc. IEEE Int. Conf. on Systems, Man, and Cybernetics, pp.6-14, 1993.
DOI : 10.1109/robot.1993.291978
A. Goudali, J. Lallemand, and S. Zeghloul, Modeling of the 2-delta decoupled parallel robot, Proc. 6 th Int. Symp. on Robotics and Manufacturing, WAC'96, vol.6, pp.243-248, 1996.
V. E. Gough, Contribution to discussion of papers on research in automobile stability, control and tyre performance, Proc. Auto. Div. Inst. Mech. Eng, pp.1956-1957
T. N. Greville, Some applications of the pseudo-inverse of a matrix, SIAM Review, vol.2, issue.1, pp.15-22, 1960.
G. Z. Grudi? and P. D. Lawrence, Iteratitive inverse kinematics with manipulator configuration control, IEEE Trans. on Robotics and Automation, vol.9, issue.4, pp.476-483, 1993.
M. Modeling-;-guglielmi, E. Jonker, and J. Piasco, Modelisation and identification of a two degrees of freedom SCARA robot using extended Kalman filtering, Proc. Int. Conf. on Advanced Robotics, ICAR'87, pp.137-148, 1987.
G. Guyot, Contribution à l'étalonnage géométrique des robots manipulateurs, 1995.
I. J. Ha, M. S. Ko, and S. K. Kwon, An efficient estimation algorithm for the model parameters of robotic manipulators, IEEE Trans. on Robotics and Automation, vol.5, issue.6, pp.386-394, 1989.
W. Hahn, Stability of Motion, 1967.
K. Han, W. K. Chung, and Y. Youm, Local structurization for the forward kinematics of parallel manipulators using extra sensor data, Proc. IEEE Int. Conf. on Robotics and Automation, pp.514-520, 1995.
S. A. Hayati, Robot arm geometric link parameter estimation, Proc. 22 nd IEEE Conf. Decision and Control, pp.1477-1483, 1983.
DOI : 10.1109/cdc.1983.269783
V. Held and C. Maron, Estimation of friction characteristics, inertial and coupling coefficients in robotic joints based on current and speed measurements, Proc. IFAC Symp. on Robot Control, SYROCO'88, vol.6, pp.86-87, 1988.
J. Hervé, Analyse structurelle des mécanismes par groupe de déplacement, J. of Mechanism and Machine Theory, vol.13, issue.4, pp.437-450, 1978.
J. Hervé, F. Sparacino, R. Hoffman, and M. Hoffman, Structural synthesis of parallel robot generating spatial translation, Proc. 5th World Congress on Theory of Machines and Mechanisms, pp.603-606, 1979.
N. Hogan, Impedance control: an approach to manipulation, Trans. of ASME, J. of Dynamic Systems, Measurement, and Control, vol.107, pp.1-24, 1985.
N. Hogan, J. M. Hollerbach, J. M. Hollerbach, and J. M. Hollerbach, An iterative lagrangian formulation of manipulators dynamics and a comparative study of dynamics formulation complexity, Proc. IEEE Int. Conf. on Robotics and Automation, vol.10, pp.349-356, 1980.
J. M. Hollerbach and K. C. Suh, Redundancy resolution of manipulators through torque optimization, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1016-1021, 1985.
J. M. Hollerbach, J. M. Hollerbach, D. Lokhorst, J. M. Hollerbach, C. W. Wampler et al., The calibration index and taxonomy of kinematic calibration methods, The Robotics Review n°1, vol.11, pp.123-128, 1965.
R. Horowitz and M. Tomizuka, An adaptive control scheme for mechanical manipulators; compensation of non linearity and decoupling control, Presentation at the Winter Meeting of ASME, Dynamic Systems and Control Division, 1980.
T. C. Hsia, Adaptive control of robot manipulators; a review, Proc. IEEE Int. Conf. on Robotics and Automation, pp.183-189, 1986.
P. Hsu, J. Hauser, and S. Sastry, Dynamic control of redundant manipulators, Proc. IEEE Int. Conf. on Robotics and Automation, pp.183-187, 1988.
K. H. Hunt, Structural kinematics of in-parallel-actuated robot-arms, Trans of ASME, J. of Mechanisms, Transmissions, and Automation in Design, vol.105, pp.705-712, 1983.
M. Husty, An algorithm for solving the direct kinematics of Stewart-Gough-type platforms, J. of Mechanisms and Machine Theory, vol.31, issue.4, pp.365-379, 1996.
M. Ikits, J. M. Hollerbach, C. Innocenti, V. Parenti-castelli, and C. Innocenti, Analytical-form direct kinematics for the second scheme of a 5-5 general-geometry fully parallel manipulator, Proc. IEEE Int. Conf. on Robotics and Automation, vol.12, pp.661-676, 1993.
H. Inoue, Y. Tsusaka, and T. Fukuizumi, Parallel manipulator, Proc. 3 rd Int. Symp. of Robotics Research, pp.69-75, 1985.
A. Izaguirre and R. C. Paul, Automatic generation of the dynamic equations of the robot manipulators using a LISP program, Proc. IEEE Int. Conf. on Robotics and Automation, pp.220-226, 1986.
J. Z. , Study of the effect of leg inertia in Stewart platform, IEEE Int. Conf. on Robotics and Automation, pp.121-126, 1993.
R. Judd and A. Knasinski, A technique to calibrate industrial robots with experimental verification, IEEE Trans. on Robotics and Automation, vol.6, issue.1, pp.20-30, 1990.
M. E. Kahn, The near minimum time control of open loop articulated kinematic chains, 1969.
T. Kanade, P. Khosla, and N. Tanaka, Real-time control of the CMU direct-drive arm II using customized inverse dynamics, Proc. 23 rd IEEE Conf. on Decision and Control, pp.1345-1352, 1984.
T. R. Kane and D. Levinson, The use of Kane's dynamical equations in robotics, The Int. J. of Robotics Research, vol.2, issue.3, pp.3-21, 1983.
H. Kawasaki and K. Nishimura, Terminal-link parameter estimation and trajectory control of robotic manipulators, IEEE J. of Robotics and Automation, vol.4, issue.5, pp.485-490, 1988.
H. Kawasaki, B. Takahiro, and K. Kazuo, An efficient algorithm for the modelbased adaptive control of robotic manipulators, IEEE Trans. on Robotics and Automation, vol.12, issue.3, pp.496-501, 1996.
H. Kazerooni, T. Sheridan, and P. Houpt, Robust compliant motion for manipulators", Parts I and II, IEEE J. of Robotics and Automation, vol.2, issue.2, pp.83-105, 1986.
K. Kazerounian and K. C. Gupta, Manipulator dynamics using the extended zero reference position description, IEEE J. of Robotics and Automation, vol.2, issue.4, pp.221-224, 1986.
R. Kelly and R. Ortega, Adaptive control of robot manipulators: an input-output approach, Proc. IEEE Int. Conf. on Robotics and Automation, pp.699-703, 1988.
R. Kelly, A tuning procedure for stable PID control of robot manipulators, Robotica, vol.13, pp.141-148, 1995.
W. Khalil, Modélisation et commande par calculateur du manipulateur MA-23
, extension à la conception par ordinateur des manipulateurs, 1976.
W. Khalil, Contribution à la commande automatique des manipulateurs avec l'aide d'un modèle mathématique des mécanismes, 1978.
W. Khalil, A. Liegeois, and A. Fournier, Commande dynamique des robots, Revue RAIRO Automatique / Systems Analysis and Control, vol.13, pp.189-201, 1979.
W. Khalil and J. Kleinfinger, Une modélisation performante pour la commande dynamique de robots, Revue RAIRO, APII, vol.6, pp.561-574, 1985.
W. Khalil and M. Gautier, Identification of geometric parameters of robots, Proc. IFAC Symp. on Robot Control, SYROCO'85, pp.191-194, 1985.
W. Khalil and J. Kleinfinger, A new geometric notation for open and closedloop robots, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1174-1180, 1986.
W. Khalil, On the explicit derivation of the inverse geometric models of robots, Proc. IMACS-IFAC Symp, pp.541-546, 1986.
W. Khalil, J. Kleinfinger, and M. Gautier, Reducing the computational burden of the dynamic model of robots, Proc. IEEE Int. Conf. on Robotics and Automation, pp.525-531, 1986.
W. Khalil and C. Chevallereau, An efficient algorithm for the dynamic control of robots in the cartesian space, Proc. 26 th IEEE Conf. on Decision and Control, pp.582-588, 1987.
W. Khalil and J. Kleinfinger, Minimum operations and minimum parameters of the dynamic model of tree structure robots, IEEE J. of Robotics and Automation, vol.3, issue.6, pp.517-526, 1987.
W. Khalil, F. Bennis, C. Chevallereau, and J. Kleinfinger, SYMORO: a software package for the symbolic modelling of robots, Proc. 20 th Int. Symp. on Industrial Robots, pp.1023-1030, 1989.
W. Khalil, F. Bennis, and M. Gautier, Calculation of the minimum inertial parameters of tree structure robots, Proc. Int. Conf. on Advanced Robotics, ICAR'89, pp.189-201, 1989.
. Khalil, . W. Khalil, .. Caenen, and . C. Enguehard, Identification and calibration of the geometric parameters of robots, Proc. 1 st Experimental Robot Conference, vol.139, pp.528-538, 1989.
W. Khalil, F. Bennis, and M. Gautier, The use of the generalized links to determine the minimum inertial parameters of robots, J. of Robotic Systems, vol.7, issue.2, pp.225-242, 1990.
W. Khalil and F. Bennis, Calcul de la matrice d'inertie des robots à chaîne ouverte simple ou arborescente, 1990.
W. Khalil and F. Bennis, Automatic generation of the inverse geometric model of robots, J. of Robotics and Autonomous Systems, vol.7, pp.1-10, 1991.
W. Khalil and M. Gautier, Calculation of the identifiable parameters for robot calibration, Proc. IFAC Symp. on Identification and System Parameter Estimation, pp.888-892, 1991.
W. Khalil, M. Gautier, and C. Enguehard, Identifiable parameters and optimum configurations for robot calibration, Robotica, vol.9, pp.63-70, 1991.
W. Khalil and M. Gautier, Computed current control of robots, Proc. IFAC 12t h World Congress, vol.IV, pp.129-132, 1993.
W. Khalil and F. Bennis, Comments on Direct Calculation of Minimum Set of Inertial Parameters of Serial Robots, IEEE Trans. on Robotics and Automation, vol.10, issue.1, pp.78-79, 1994.
URL : https://hal.archives-ouvertes.fr/hal-00401750
W. Khalil and D. Murareci, On the general solution of the inverse kinematics of six-degrees-of-freedom manipulators, Proc. Int. Workshop on Advances in Robot Kinematics, vol.94, 1994.
W. Khalil and F. Bennis, Symbolic calculation of the base inertial parameters of closed-loop robots, The Int. J. of Robotics Research, vol.14, issue.2, pp.112-128, 1995.
W. Khalil, G. Garcia, and J. Delagarde, Calibration of the geometric parameters of robots without external sensors, Proc. IEEE Int. Conf. on Robotics and Automation, pp.3039-3044, 1995.
W. Khalil and P. P. Restrepo, An efficient algorithm for the calculation of the filtred dynamic model of robots, Proc. IEEE Int. Conf. on Robotics and Automation, pp.323-329, 1996.
W. Khalil, P. Lemoine, and M. Gautier, Autonomous calibration of robots using planar points, Proc. 6 th Int. Symp. on Robotics and Manufacturing, WAC'96, vol.3, pp.383-388, 1996.
URL : https://hal.archives-ouvertes.fr/hal-00362605
W. Khalil and D. Murareci, Kinematic analysis and singular configuration of a class of parallel robots, J. of Mathematic and Computer in Smulation, pp.1-14, 1245.
W. Khalil and D. Creusot, SYMORO+: a system for the symbolic modelling of robots, Robotica, vol.15, pp.153-161, 1997.
URL : https://hal.archives-ouvertes.fr/hal-00401687
W. Khalil and D. Murareci, Autonomous calibration of parallel robots, Proc. IFAC Symp. on Robot Control, SYROCO'97, pp.425-430, 1997.
W. Khalil and L. Ph, Gecaro: A system for the geometric calibration of robots, APII-Jesa, vol.33, pp.717-739, 1999.
URL : https://hal.archives-ouvertes.fr/hal-00362608
W. Khalil and P. Lemoine, Gecaro: a system for the geometric calibration of robots, Revue APII-JESA, vol.33, issue.5-6, pp.717-739, 1999.
W. Khalil and S. Besnard, Self calibration of Stewart-Gough parallel robots without extra sensors, IEEE Trans. on Robotics and Automation, vol.15, issue.6, pp.1116-1121, 1999.
W. Khalil and M. Gautier, Modeling of mechanical systems with lumped elasticity, Proc. IEEE Int. Conf. on Robotics and Automation, pp.3965-3970, 2000.
W. Khalil, S. Besnard, and P. Lemoine, Comparison study of the geometric parameters calibration methods, Int. J. of Robotics and Automation, vol.15, issue.2, pp.56-67, 2000.
URL : https://hal.archives-ouvertes.fr/hal-00362616
W. Khalil, Commande des robots, Série IC2, Hermès, 2002.
URL : https://hal.archives-ouvertes.fr/hal-00630760
W. Khalil and E. Dombre, Modeling, identification and control of robots, Hermes Penton, 2002.
W. Khalil and S. Guegan, Inverse and Direct Dynamic Modeling of Gough-Stewart Robots, IEEE Transactions on Robotics and Automation, vol.20, issue.4, pp.754-762, 2004.
URL : https://hal.archives-ouvertes.fr/hal-00401751
W. Khalil and O. Ibrahim, General solution for the Dynamic modeling of parallel robots, Journal of Intelligent and Robotic Systems, vol.49, pp.19-37, 2007.
URL : https://hal.archives-ouvertes.fr/hal-00401684
W. Khalil, W. Gautier, M. , L. Ph, ;. Khalil et al., Identification of the payload inertial parameters of industrial manipulators, Part C: Application and reviews, vol.37, pp.3-20, 2007.
URL : https://hal.archives-ouvertes.fr/hal-00362677
O. Khatib, Commande dynamique dans l'espace opérationnel des robotsmanipulateurs en présence d'obstacles, 1980.
O. Khatib, A unified approach for motion and force control of robot manipulators: the operational space formulation, IEEE J. of Robotics and Automation, vol.3, issue.1, pp.43-53, 1987.
M. Khelfi, Observateurs non linéaires : application à la commande des robots manipulateurs, 1995.
D. Kholi and J. Spanos, Workspace analysis of mechanical manipulators using polynomial discriminants, J. of Mechanisms, Transmissions, and Automation in Design, vol.107, pp.209-215, 1985.
D. Kholi and M. S. Hsu, The jacobian analysis of workspaces of mechanical manipulators, J. of Mechanisms and Machine Theory, vol.22, issue.3, pp.265-275, 1987.
P. K. Khosla and T. Kanade, Parameter identification of robot dynamics, Proc. 24 th IEEE Conf. on Decision and Control, pp.1754-1760, 1985.
P. K. Khosla, Real-time control and identification of direct drive manipulators, 1986.
M. Kircánski and M. Vukobratovic, Computer-aided generation of manipulator kinematic models in symbolic form, Proc. 15 th Int. Symp. on Industrial Robots, pp.1043-1049, 1985.
C. A. Klein and C. Huang, Review of pseudo inverse control for use with kinematically redundant manipulators, IEEE Trans. on Systems, Man, and Cybernetics, vol.13, issue.2, pp.245-250, 1983.
C. A. Klein, Use of redundancy in the design of robotic systems, Proc. 2 nd Int. Symp. of Robotic Research, pp.58-65, 1984.
C. A. Klein and A. S. Chu-jenq, A new formulation of the extended Jacobian method and its use in mapping algorithmic singularities for kinematically redundant manipulators, IEEE Trans. on Robotics and Automation, vol.11, issue.1, pp.50-55, 1986.
J. Kleinfinger and W. Khalil, Dynamic modelling of closed-chain robots, Proc. 16 th Int. Symp. on Industrial Robots, pp.401-412, 1986.
V. C. Klema and A. J. Lanio, The singular value decomposition: its computation and some applications, Proc. 23 rd IEEE Conf. on Decision and Control, vol.25, pp.737-735, 1980.
M. S. Konstantinov, M. D. Markov, and D. N. Nenchev, Kinematic control of redundant manipulators, Proc. 11 th Int. Symp. on Industrial Robots, pp.561-568, 1981.
F. Korrami and U. Özgnüner, Decentralized control of robot manipulators via state and proportional-integral feedback, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1198-1203, 1988.
E. J. Kreuzer, Dynamical analysis of mechanisms using symbolical equation manipulation, Proc. 5 th World Congress on Theory of Machines and Mechanisms, pp.599-602, 1979.
I. Landau, Adaptive control; The model reference approach, 1979.
I. D. Landau and R. Horowitz, Synthesis of adaptive controllers for robot manipulators using a passive feedback system approach, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1028-1033, 1988.
S. Lavallée, Procédé d'étalonnage d'un robot
C. L. Lawson and R. J. Hanson, Solving Least Squares Problems, 1974.
D. Lazard, Stewart platforms and Grübner basis, Proc. 3 rd Int. Workshop on Advances in Robot Kinematics, vol.92, pp.136-142, 1992.
L. Borzec, R. Lotterie, and J. , Principes de la théorie des mécanismes, Dunod, 1975.
G. Lebret, G. K. Liu, and F. L. Lewis, Dynamic analysis and control of a Stewart platform manipulator, J. of Robotic Systems, vol.10, issue.5, pp.629-655, 1993.
URL : https://hal.archives-ouvertes.fr/hal-01147121
C. S. Lee and M. Ziegler, A geometric approach in solving the inverse kinematics of PUMA robots, Proc. 13 th Int. Symp. on Industrial Robots, pp.16-18, 1983.
H. Y. Lee and C. G. Liang, Displacement analysis of the general 7-link 7R mechanism, J. of Mechanism and Machine Theory, vol.23, issue.3, pp.219-226, 1988.
K. M. Lee and D. Shah, Dynamic analysis of a three-degrees-of-freedom in-parallel actuated manipulator, IEEE J. of Robotics and Automation, vol.4, issue.3, pp.361-368, 1988.
H. Y. Lee and B. Roth, A closed-form solution of the forward displacement analysis of a class of in-parallel robots, Proc. IEEE Int. Conf. on Robotics and Automation, pp.720-724, 1993.
J. Léon, Modélisation et construction de surfaces pour la CFAO, 1991.
F. L. Lewis, C. T. Abdallah, and D. M. Dawson, Control of robot manipulators, 1993.
W. Li and J. E. Slotine, An indirect adaptive robot controller, Systems & Control Letters, vol.12, pp.259-266, 1989.
A. Liégeois, E. Dombre, M. Liu, C. Li, and C. Li, Analyse des robots industriels ; relations entre structures, performances et fonctions, IEEE Transaction on Robotics and Automation, vol.79102, issue.1, pp.94-98, 1979.
K. W. Lilly and D. E. Orin, Efficient O(N) computation of the operational space inertia matrix, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1014-1019, 1990.
C. S. Lin, P. R. Chang, and J. Y. Luh, Formulation and optimization of cubic polynomial joint trajectories for industrial robots, IEEE Trans. on Automatic Control, vol.28, issue.12, pp.1066-1073, 1983.
W. Lin, M. Griffis, and J. Duffy, Forward displacement analysis of the 4-4 Stewart platforms, J. of Mechanical Design, vol.114, pp.444-450, 1992.
M. Llibre, R. Mampey, and J. P. Chrétien, Simulation de la dynamique des robots manipulateurs motorisés, Congrès AFCET : Productique et Robotique Intelligente, pp.197-207, 1983.
J. E. Llyod, Using Puiseux series to control non-redundant robots at singularities, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1877-1882, 1996.
Z. Lu, K. B. Shimoga, and A. Goldberg, Experimental determination of dynamic parameters of robotic arms, J. of Robotic Systems, vol.10, issue.8, pp.1009-1029, 1993.
J. Y. Luh, M. W. Walker, and R. C. Paul, Resolved-acceleration control of mechanical manipulators, IEEE Trans. on Automatic Control, vol.25, issue.3, pp.468-474, 1980.
J. Y. Luh, M. W. Walker, and R. C. Paul, On-line computational scheme for mechanical manipulators, Trans. of ASME, J. of Dynamic Systems, Measurement, and Control, vol.102, issue.2, pp.69-76, 1980.
J. Y. Luh and Y. L. Gu, Industrial robots with seven joints, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1010-1015, 1985.
J. Y. Luh and Y. F. Zheng, Computation of input generalized forces for robots with closed kinematic chain mechanisms, IEEE J. of Robotics and Automation, vol.1, issue.2, pp.95-103, 1985.
O. Ma and J. Angeles, Architecture singularities of platform manipulators, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1542-1547, 1991.
A. A. Maciejewski and C. A. Klein, Obstacle avoidance for kinematically redundant manipulators in dynamically varying environments, The Int. J. of Robotics Research, vol.4, issue.3, pp.109-117, 1985.
]. Maciejewski, A. A. Maciejewski, and C. A. Klein, Numerical filtering operation of robotic manipulators throuh kinematically singular configurations, J. of Robotic Systems, vol.5, issue.6, pp.527-552, 1988.
A. A. Maciejewski and C. A. Klein, The singular value decomposition: computation and applications to robotics, The Int. J. of Robotics Research, vol.8, issue.6, pp.63-79, 1989.
O. Manaoui, Calcul automatique de transformateurs de coordonnées analytiques de robots à partir de classes de solutions préétablies, 1985.
N. Mansard, N. Mansard, and . Chaumette, Université de Rennes 1, Mention informatique, IEEE Trans, 2006.
. Robotics, , vol.23, pp.60-72, 2007.
M. T. Mason, Compliant motion, Robot motion: planning and control, 1982.
P. Maurine, Développement et mise en oeuvre de méthodologies d'étalonnage de robots manipulateurs industriels, 1996.
C. Mavroidis, Résolution du problème géométrique inverse pour les manipulateurs série à six degrés de liberté, 1993.
H. Mayeda, K. Osuka, and A. Kangawa, A new identification method for serial manipulator arms, Proc. IFAC 9 th World Congress, pp.74-79, 1984.
H. Mayeda, K. Yoshida, and K. Osuka, Base parameters of manipulator dynamic models, IEEE Trans. on Robotics and Automation, vol.6, issue.3, pp.312-321, 1990.
S. Megahed and M. Renaud, Minimization of the computation time necessary for the dynamic control, Proc. 12 th Int. Symp. on Industrial Robots, pp.469-478, 1982.
S. Megahed, Contribution à la modélisation géométrique et dynamique des robots manipulateurs ayant une structure de chaîne cinématique simple ou complexe
J. M. Mendel, Discrete techniques of parameter estimation: the equation error formulation, 1973.
J. Merlet, Contribution à la formalisation de la commande par retour d'effort en robotique ; application à la commande de robots parallèles, 1986.
J. Merlet, Singular configurations of parallel manipulators and Grassmann geometry, The Int. J. of Robotics Research, vol.8, issue.5, pp.45-56, 1989.
J. Merlet, Closed-form resolution of the direct kinematics of parallel manipulators using extra sensor data, Proc. IEEE Int. Conf. on Robotics and Automation, pp.200-204, 1993.
J. Merlet, Parallel robots, 2000.
URL : https://hal.archives-ouvertes.fr/lirmm-00127856
R. H. Middleton-;-middleton and G. C. Goodwin, Adaptive computed torque control for rigid link manipulators, Systems & Control Letters, vol.10, pp.9-16, 1988.
V. Milenkovic, B. Huang, and K. Miller, Optimal Design and Modeling of Spatial Parallel Manipulators, Proc. 13 th Int. Symp. on Industrial Robots, vol.47, pp.127-140, 1983.
B. W. Mooring, Z. S. Roth, and M. R. Driels, Fundamentals of manipulator calibration, 1991.
G. Morel, Y. F. Moroskine, and Y. F. Moroskine, General analysis of the theory of mechanisms, Programmation et adaptation d'impédance de manipulateurs au contact, vol.14, pp.269-272, 1954.
D. Murareci, Contribution à la modélisation géométrique et à l'étalonnage des robots séries et parallèles, 1997.
S. H. Murphy and J. T. Wen, Analysis of active manipulator elements in space manipulation, IEEE Trans. on Robotics and Automation, vol.9, issue.5, pp.544-552, 1993.
J. J. Murray and C. P. Newman, ARM: an algebraic robot dynamic modeling program, Proc. IEEE Int. Conf. on Robotics and Automation, pp.103-104, 1984.
A. Nahvi, J. M. Hollerbach, and V. Hayward, Calibration of parallel robot using multiple kinematic closed loops, Proc. IEEE Int. Conf. on Robotics and Automation, pp.407-412, 1994.
Y. Nakamura and Y. Hanafusa, Inverse kinematic solutions with singularity robustness for robot manipulator control, Trans. of ASME, J. of Dynamic Systems, Measurement, and Control, vol.108, pp.163-171, 1986.
Y. Nakamura, Y. Hanafusa, and T. Yoshikawa, Task-priority based redundancy control of a robot manipulator, The Int. J. of Robotics Research, vol.6, issue.2, pp.3-15, 1987.
P. Nanua, K. J. Waldron, V. Murthy, and D. N. Nenchev, Restricted jacobian matrices of redundant manipulators in constrained motion tasks, IEEE Trans. on Robotics and Automation, vol.6, issue.4, pp.584-597, 1990.
J. L. Nevins and D. E. Whitney, The force vector assembler concept, Proc. 1 st CISM-IFToMM Symp. on Theory and Practice of Robots and Manipulators, pp.273-288, 1973.
J. L. Nevins, Exploratory research in industrial modular assembly, 1111.
W. H. Newman and R. F. Sproull, Principles of interactive computer graphics, 1979.
S. Nicosia and P. Tomei, Model reference adaptive control algorithms for industrial robots, Automatica, vol.20, issue.5, pp.635-644, 1984.
S. Nicosia and P. Tomei, Robot control by using only joint position measurements, IEEE Trans. on Automatic Control, vol.35, issue.5, pp.1058-1061, 1990.
L. Nielsen, C. Canudas-de-wit, and P. Hagander, Controllability issues of robots near singular configurations, Advanced Robot Control, pp.307-314, 1991.
H. B. Olsen and G. A. Bekey, Identification of robot dynamics, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1004-1010, 1986.
D. E. Orin, R. B. Mcghee, M. Vukobratovic, and G. Hartoch, Kinematic and kinetic analysis of open-chain linkages utilizing Newton-Euler methods, Mathematical Biosciences, vol.43, pp.107-130, 1979.
R. Ortega and M. W. Spong, Adaptive motion control of rigid robots: a tutorial, Automatica, vol.25, issue.6, pp.877-888, 1989.
B. Paden and R. Panja, Globally asymptotically stable 'PD+' controller for robot manipulator, Int. J. Control, vol.47, pp.877-888, 1988.
R. C. Paul, Modelling, trajectory calculation, and servoing of a computer controlled arm, 1972.
R. C. Paul, Robot manipulators: mathematics, programming and control, 1981.
D. Payannet, Modélisation et correction des erreurs statiques des robots manipulateurs, 1985.
R. Penrose, A generalized inverse for matrices, Proc. Cambridge Philos. Soc, vol.51, pp.406-413, 1955.
V. Perdereau, Contribution à la commande hybride force-position, 1991.
C. Pham, P. Chedmail, and M. Gautier, Determination of base parameters of flexible links manipulators, Proc. IMACS MCTS Symposium, Modelling and Control of Technological Systems, vol.1, pp.524-529, 1991.
C. Pham and M. Gautier, Essential parameters of robots, Proc. 30 th IEEE Conf. on Decision and Control, pp.2769-2774, 1991.
M. T. Pham, M. Gautier, and P. Poignet, Identification of joint stiffness with bandpass filtering, Int. Conf. on Robotics and Automation, 2001.
D. L. Pieper, The kinematics of manipulators under computer control, 1968.
F. Pierrot, Robots pleinement parallèles légers : conception, modélisation et commande, 1991.
F. Pierrot, A. Fournier, and P. Dauchez, Towards a fully-parallel six dof robot for hight-speed applications, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1288-1293, 1991.
P. Pledel, Génération de mouvements optimaux pour un robot manipulateur, 1996.
P. Poignet and M. Gautier, Comparison of weighted least squares and extended kalman filtering methods for dynamic identification of robots, Proc. IEEE Int. Conf. on Robotics and Automation, pp.3622-3627, 2000.
V. M. Popov and V. Potkonjak, Thermal criterion for the selection of DC drives for industrial robots, Proc. 16 th Int. Symp. on Industrial Robots, pp.129-140, 1973.
M. J. Powell, An efficient method for finding the minimum of a function of several variables without calculating derivatives, The Computer Journal, vol.7, pp.155-162, 1964.
C. Pressé and M. Gautier, New criteria of exciting trajectories for robot identification, Proc. IEEE Int. Conf. on Robotics and Automation, pp.907-912, 1993.
C. Pressé, Identification des paramètres dynamiques des robots, 1994.
M. Priel, Les robots industriels : caractéristiques, performance et choix, Collection AFNOR Technique, 1990.
M. Prüfer, C. Schmidt, and F. Wahl, Identification of robots dynamics with differential and integral models: a comparison, Proc. IEEE Int. Conf. on Robotics and Automation, pp.340-345, 1994.
A. Pujas, Etude de la robustesse de schémas de commande position / force pour robots à deux bras, 1995.
Z. Qu and J. Dorsey, Robust PID control of robots, Int. J. Robotics and Automation, vol.6, issue.4, pp.228-235, 1991.
M. Raghavan, B. Roth, and M. Raghavan, Inverse kinematics of thegeneral 6R manipulator and related linkages, Advances in Design Automation, vol.115, pp.397-402, 1990.
M. H. Raibert, Analytic equations vs. table look-up for manipulation: a unifying concept, Proc. 16 th IIEEE Conf. on Decision and Control, pp.576-579, 1977.
M. H. Raibert and B. K. Horn, Manipulator control using the configuration space method, The Industrial Robot, vol.5, issue.2, pp.69-73, 1978.
M. H. Raibert, J. J. Craig, and B. Raucent, Identification des paramètres dynamiques des robots manipulateurs, Trans. of the ASME, J. of Dynamic Systems, Measurement, and Control, vol.103, pp.126-133, 1981.
B. Raucent, G. Bastin, G. Campion, J. Samin, and P. Y. Willems, Identification of barycentric parameters of robotic manipulators from external measurements, Automatica, vol.28, issue.5, pp.1011-1016, 1992.
C. Reboulet and A. Robert, Hybrid control of a manipulator equipped with an active compliant wrist, Proc. 3 rd Int. Symp. of Robotics Research, pp.76-80, 1985.
C. Reboulet, C. Reboulet, and T. Berthomieu, Dynamic models of a six degree of freedom parallel manipulators, Techniques de la robotique : architectures et commandes, Hermès, pp.1153-1157, 1988.
M. Renaud, Contribution à l'étude de la modélisation et de la commande des 490 Modeling, identification and control of robots systèmes mécaniques articulés, 1975.
M. Renaud, Contribution à la modélisation et à la commande dynamique des robots manipulateurs, UPS, 1980.
M. Renaud, Calcul de la matrice jacobienne nécessaire à la commande coordonnée d'un manipulateur, J. of Mechanism and Machine Theory, vol.15, issue.1, pp.81-91, 1980.
M. Renaud, A near minimum iterative analytical procedure for obtaining a robot-manipulator dynamic model, IUTAM/IFToMM Symp. on Dynamics of Multi-body Systems, 1985.
M. Renaud, Quasi-minimal computation of the dynamic model of a robot manipulator utilizing the Newton-Euler formalism and the notion of augmented body, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1677-1682, 1987.
P. P. Restrepo and M. Gautier, Calibration of drive chain of robot joints, Proc. 4t h IEEE Conf. on Control Applications, CCA'95, pp.526-531, 1995.
P. P. Restrepo, Contribution à la modélisation, identification et commande des robots à structures fermées : application au robot Acma SR400, 1996.
J. Richalet and A. Robert, Commande hybride position-force ; mise en oeuvre et expérimentation sur un micro-ordinateur parallèle, 1986.
L. G. Roberts, Homogeneous matrix representation and manipulation of Ndimensional constructs, MS 1405, 1965.
P. Rocco, Stability of PID control for industrial robot arms, IEEE Trans. on Robotics and Automation, vol.12, issue.4, pp.607-614, 1996.
B. Roth, Performance evaluation of manipulators from a kinematic viewpoint, pp.233-263, 1976.
Z. S. Roth, B. W. Mooring, and B. Ravani, An overview of robot calibration, IEEE J. of Robotics and Automation, vol.3, issue.5, pp.377-385, 1987.
N. Sadegh and R. Horowitz, Stability analysis of an adaptive controller for robotic manipulators, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1223-1229, 1987.
N. Sadegh and R. Horowitz, Stability and robustness analysis of a class of adaptive controllers for robotic manipulators, The Int. J. of Robotics Research, vol.9, issue.3, pp.74-92, 1990.
J. K. Salisbury, Active stiffness control of a manipulator in cartesian coordinates, Proc. 19 th IEEE Conf. on Decision and Control, pp.95-100, 1980.
G. Salmon and C. Samson, Problèmes en identification et commande de systèmes dynamiques, 1885.
C. Samson, Robust control of a class of non-linear systems and applications to robotics, Int. J. of Adaptive Control and Signal Processing, vol.1, pp.49-68, 1987.
C. Samson, L. Borgne, M. Espiau, B. , and R. Control, , 1991.
B. Schefer, Geometric control and calibration method of an industrial robot, Proc. 12th Int. Symposium on Industrial Robotics, pp.331-339, 1982.
L. Sciavicco, B. Siciliano, and L. Villani, On dynamic modelling of gear-driven rigid robot manipulators, Proc. 4 th IFAC Symp. on Robot Control, SYROCO'94, pp.543-549, 1994.
F. Sgarbi and R. Cammoun, Real time trajectory generation using filtering techniques, Proc. 2 nd Int. Conf. on Automation, Robotics, and Computer Vision, ICARCV'92, 1992.
P. N. Sheth and J. J. Uicker, A generalized symbolic notation for mechanism, Trans. of ASME, J. of Engineering for Industry, vol.93, pp.102-112, 1971.
Z. Shiller, On singular time-optimal control along specified paths, IEEE Trans. on Robotics and Automation, vol.10, issue.4, pp.561-566, 1994.
K. G. Shin and N. D. Mckay, Minimum time control of robotic manipulators with geometric path constraints, IEEE Trans. on Automatic Control, vol.30, issue.6, pp.531-541, 1985.
B. Siciliano, L. Villani, B. Siciliano, and L. Villani, A passivity-based approach to force regulation and motion control of robot manipulators, Int. J. of Adaptive Control and Signal Processing, vol.7, pp.443-447, 1993.
. Siciliano, B. Siciliano, and L. Villani, Adaptive compliant control of robot manipulators, Control Engineering Practice, vol.4, pp.705-712, 1996.
DOI : 10.1016/0967-0661(96)00054-8
B. Siciliano and L. Villani, Robot force control, Springer hand book of Robotics, 2000.
J. E. Slotine and W. Li, Adaptive manipulator control: a case study, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1312-1400, 1987.
DOI : 10.1109/robot.1987.1087895
J. E. Slotine and W. Li, Applied Nonlinear Control, 1991.
D. A. Smith, M. A. Chace, and A. C. Rubens, The automatic generation of a mathematical model for machinery systems, Trans. of ASME, J. of Engineering for Industry, vol.95, pp.629-635, 1973.
J. Spanos and D. Kholi, Workspace analysis of regional structures of manipulators, J. of Mechanisms, Transmissions, and Automation in Design, vol.107, pp.219-225, 1985.
R. Spetch and R. Isermann, On-line identification of inertia, friction and gravitational forces applied to an industrial robot, Proc. IFAC Symp. on Robot Control, SYROCO'88, p.88, 1988.
M. W. Spong, Modeling and control of elastic joint robots, Trans. of the ASME, J. of Dynamic Systems, Measurement, and Control, vol.109, pp.310-319, 1987.
M. W. Spong and M. Vidyasagar, Robot dynamics and control, 1989.
M. W. Spong, Y. Stepanenko, and J. Yuan, A reduced order regressor and its application to adaptive robotic control, The Int. J. of Robotics Research, vol.12, issue.2, pp.180-187, 1993.
D. Stewart, A platform with six degrees of freedom, Proc. of Institution of Mechanical Engineers, vol.180, pp.371-385, 1965.
K. Sugimoto and T. Okada, Compensation of positionning errors caused by geometric deviations in robot systems, The 3 rd Int. Symp. of Robotics Research, pp.231-236, 1985.
K. Sugimoto, Computational scheme for dynamic analysis of parallel manipulators, J. of mechanics, Transmission and Automation in Design, vol.111, pp.29-33, 1989.
J. Swevers, C. Ganseman, D. B. Tükel, J. D. De-schutter, and H. Van-brussel, Optimal robot excitation and identification, IEEE Transactions on Robotics and Automation, vol.13, issue.5, pp.730-740, 1997.
M. Takegaki and S. Arimoto, An adaptive trajectory control of manipulators, Int. J. Control, vol.34, issue.2, pp.219-230, 1981.
M. Takegaki and S. Arimoto, A new feedback method for dynamic control of manipulators, Trans. of ASME, J. of Dynamic Systems, Measurement, and Control, vol.102, pp.119-125, 1981.
L. Tancredi, De la simplification et la résolution du modèle géométrique direct des robots parallèles, Ecole Nationale Supérieure des Mines de, 1995.
G. R. Tang and L. S. Lieu, A study of three robot calibration methods based on flat surfaces, J. of Mechanism and Machine Theory, vol.29, issue.2, pp.195-206, 1994.
R. H. Taylor, Planning and execution of straight line manipulator trajectories, IBM J. of Research and Development, vol.23, issue.4, pp.424-436, 1979.
X. Thérond, E. Dégoulange, E. Dombre, and F. Pierrot, Force control of a medical robot for arterial diseases detection, Proc. 6 th Int. Symp. on Robotics and Manufacturing, WAC'96, vol.6, pp.793-798, 1996.
P. Tomei, Adaptive PD controller for robot manipulators, IEEE Trans. on Robotics and Automation, vol.7, issue.4, pp.565-570, 1991.
B. Tondu and H. El-zorkany, Identification of a trajectory model for the PUMA-560 Robot, J. of Robotic Systems, vol.11, issue.2, pp.77-90, 1994.
P. Touron, Modélisation de la dynamique des mécanismes polyarticulés
L. Tsai, CAO et à la simulation de robots, vol.493, 1984.
, manipulator by the principle of virtual work, J. of Mechanical design, vol.122, pp.3-9, 2000.
J. J. Uicker, Dynamic behavior of spatial linkages, Trans. of ASME, J. of Engineering for Industry, vol.91, pp.251-258, 1969.
P. Vandanjon, M. Gautier, and P. Desbats, Identification of inertial parameters of robots by means of spectrum analysis, Proc. IEEE Int. Conf. on Robotics and Automation, pp.3033-3038, 1995.
W. K. Veitschegger and C. H. Wu, Robot accuracy analysis based on kinematics, IEEE J. of Robotics and Automation, vol.2, issue.3, pp.171-179, 1986.
G. Venture, P. Ripert, W. Khalil, M. Gautier, P. Bodson-;-volpe et al., A theoretical and experimental investigation of explicit force control for manipulators, IEEE Transactions on Intelligent Transportation Systems, vol.7, issue.11, pp.1634-1650, 1993.
R. Volpe and P. Khosla, The equivalence of second-order impedance control and proportional gain explicit force control, The Int. J. of Robotics Research, vol.14, issue.6, pp.574-589, 1995.
M. Vukobratovic and V. Potkonjak, Dynamics of manipulation robots
, Theory and applications, vol.1, 1982.
M. Vukobratovic and N. Kircanski, Real-time dynamics of manipulation robots, 1985.
M. W. Walker and D. E. Orin, Efficient dynamic computer simulation of robotics mechanism, Trans. of ASME, J. of Dynamic Systems, Measurement, and Control, vol.104, pp.205-211, 1982.
C. W. Wampler, Manipulator inverse kinematic solutions based on vector formulation and damped least-sqares methods, IEEE Trans. on Systems, Man, and Cybernetics, vol.16, pp.93-101, 1986.
L. T. Wang and B. Ravani, Recursive computations of kinematic and dynamic equations for mechanical manipulators, IEEE J. of Robotics and Automation, vol.1, issue.3, pp.124-131, 1983.
L. C. Wang and C. C. Chen, A combined optimisation method for solving the inverse kinematics problem of mechanical manipulators, IEEE Trans. on Robotics and Automation, vol.7, issue.4, pp.489-499, 1991.
D. Wang and N. H. Mcclamroch, Position and force control for constrained manipulator motion: Lyapunov's direct method, IEEE Trans. on Robotics and Automation, vol.9, issue.3, pp.308-313, 1993.
J. T. Wen and D. Bayard, New class of control laws for robotic manipulators; Part 1: non-adaptive case, Int. J. Control, vol.47, issue.5, pp.1361-1385, 1988.
J. Wen and S. Murphy, Stability analysis of position and force control for robot arms, IEEE Trans. on Automatic Control, vol.36, pp.365-371, 1991.
P. Wenger, Aptitude d'un robot manipulateur à parcourir son espace de travail en présence d'obstacles, ENSM, 1989.
P. Wenger, A new general formalism for the kinematic analysis of all non redundant manipulators, Proc. IEEE Int. Conf. on Robotics and Automation, pp.442-447, 1992.
P. Wenger, A classification of manipulator geometries based on singularity avoidance ability, Proc. Int. Conf. on Advanced Robotics, ICAR'93, pp.649-654, 1993.
H. West, E. Papadopoulos, S. Dubowsky, and H. Cheah, A method for estimating the mass properties of a manipulator by measuring the reaction moments at its base, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1510-1516, 1989.
D. E. Whitney, Resolved motion rate control of manipulators and human prostheses, IEEE Trans. on Man Machine Systems, vol.10, issue.2, pp.47-53, 1969.
D. E. Whitney, The mathematics of coordinated control of prosthetic arms and manipulators, Trans. of ASME, J. of Dynamic Systems, Measurement, and Control, vol.94, pp.303-309, 1972.
D. E. Whitney and J. Nevins, What is the remote center compliance (RCC) and what can it do, Proc. 9 th Int. Symp. on Industrial Robots, pp.135-147, 1979.
D. E. Whitney, Historical perspective and state of the art in robot force control, Proc. IEEE Int. Conf. on Robotics and Automation, pp.262-268, 1985.
D. E. Whitney, C. A. Lozinski, J. M. Rourke, and J. Wittenburg, Industrial robot forward calibration method and results, Dynamics of system of rigid bodies, vol.108, pp.1-8, 1977.
J. Wittenburg and U. Holtz, The program MESA VERDE for robot dynamics simulations, The 3 rd Int. Symp. of Robotics Research, pp.197-204, 1985.
C. H. Wu, A kinematic CAD tool for the design and control of robot manipulators, The Int. J. of Robotics Research, vol.3, issue.1, pp.74-85, 1984.
T. Yabuta, Nonlinear basic stability concept of the hybrid position/force control scheme for robot manipulators, IEEE Trans. on Robotics and Automation, vol.8, issue.5, pp.663-670, 1992.
A. T. Yang and F. Freudenstein, Application of dual number quaternion algebra in the analysis of spatial mechanisms, Trans. of ASME, J. of Applied Mechanics, vol.33, pp.300-308, 1966.
T. Yoshikawa, Analysis and control of robot manipulators with redundancy, The 1 st Int. Symp. of Robotics Research, pp.735-748, 1984.
K. Yoshoda and W. Khalil, Verification of the positive definiteness of the inertial matrix of manipulators using base inertial parameters, Int. Journal of robotics research, vol.19, issue.5, pp.498-510, 2000.
T. Yoshikawa, Manipulability of robotics mechanisms, Proc. 2 nd Int. Symp. of Robotics Research, pp.91-98, 1984.
Z. Iturralde and J. , Commande des robots-manipulateurs à partir de la modélisation de leur dynamique, UPS, 1978.
S. Zeghloul, Développement d'un système de CAO Robotique intégrant la planification de tâches et la synthèse de sites robotisés, 1991.
W. Zghaib, Génération symbolique automatique des équations de la dynamique des systèmes mécaniques complexes avec contraintes cinématiques, 1992.
C. Zhang and S. M. Song, Forward kinematics of a class of parallel (Stewart) platforms with closed-form solutions, J. of Robotic Systems, vol.9, issue.1, pp.93-112, 1992.
X. L. Zhong and J. M. Lewis, A new method for autonomous robot calibration, Proc. IEEE Int. Conf. on Robotics and Automation, pp.1790-1795, 1995.
X. L. Zhong,
H. Zhuang, O. Masory, and J. Yan, Kinematic calibration of a Stewart platform using pose measurements obtained by a single theodolite, Proc. 1995 Int. Conf. on Intelligent Robots and Systems, IROS'95, pp.329-334, 1995.
H. Zhuang, Self-calibration of a class of parallel mechanisms with a case study on Stewart platform, IEEE Trans. on Robotics and Automation, vol.13, issue.3, pp.387-397, 1997.
, Theory of robot control, C. Canudas de, 1996.
, Modélisation, identification et commande des robots
