The Sample Average Approximation Method for Stochastic Programs with Integer Recourse, pp.1-24, 2002. ,
Profit-oriented disassembly-line balancing, International Journal of Production Research, vol.5, issue.10, pp.2675-2693, 2008. ,
DOI : 10.1287/mnsc.11.7.727
URL : http://research.sabanciuniv.edu/8621/1/Altekin_et_al_2008_-_ProfitOrientedDisassemblyLineBalancing_-_Preprint.pdf
State-of-the-Art-Survey???Stochastic Programming: Computation and Applications, INFORMS Journal on Computing, vol.9, issue.2, pp.111-133, 1997. ,
DOI : 10.1287/ijoc.9.2.111
L-shaped Method for Two-stage Problems of Stochastic Convex Programming, 1993. ,
Supply Chain Engineering: Useful Methods and Techniques, 2010. ,
DOI : 10.1007/978-1-84996-017-5
URL : https://hal.archives-ouvertes.fr/emse-00675734
A solution approach to the disassembly line balancing problem in the presence of task failures, International Journal of Production Research, vol.39, issue.7, pp.1427-1467, 2001. ,
DOI : 10.1080/00207540110052157
Issues in environmentally conscious manufacturing and product recovery: a survey, Computers & Industrial Engineering, vol.36, issue.4, pp.811-853, 1999. ,
DOI : 10.1016/S0360-8352(99)00167-9
Disassembly line in product recovery, International Journal of Production Research, vol.5, issue.11, pp.2569-2589, 2002. ,
DOI : 10.1023/A:1018500603358
Stochastic programming, European Journal of Operational Research, vol.10, issue.2, 1994. ,
DOI : 10.1016/0377-2217(82)90152-7
Two exact formulations for disassembly line balancing problems with task precedence diagram construction using an AND/OR graph, IIE Transactions, vol.41, issue.10, pp.866-881, 2009. ,
DOI : 10.1016/j.ejor.2004.07.022
Fenchel decomposition for stochastic mixed-integer programming, Journal of Global Optimization, vol.19, issue.2-3, pp.1-23, 2010. ,
DOI : 10.1007/s10898-011-9817-8
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.414.2604
A methodology for solving single-model, stochastic assembly line balancing problem, Omega, vol.27, issue.5, pp.525-535, 1999. ,
DOI : 10.1016/S0305-0483(99)00016-X
URL : http://repository.bilkent.edu.tr/bitstream/11693/13587/1/10.1016-S0305-0483%2899%2900016-X.pdf
A Cost-Based Methodology for Stochastic Line Balancing with Intermittent Line Stoppages, Management Science, vol.32, issue.4, pp.455-463, 1986. ,
DOI : 10.1287/mnsc.32.4.455
