A heuristic branch-cut-and-price algorithm for the ROADEF/EURO challenge on Inventory Routing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transportation Science Année : 2020
This paper is part of the special section devoted to the ROADEF/EURO challenge on Inventory Routing. We propose an extended formulation that we address with a heuristic branch-price-and-cut method. Among the difficulties, that we had to face, are: a fractional objective function, the simultaneous generation of constraints and columns, and a complex pricing problem. We evaluate our approach on the benchmark instances proposed for the challenge.
IRP_article_170916.pdf (327.74 Ko) Télécharger le fichier
emse-02163171 , version 1 (24-06-2019)
Nabil Absi, Diego Cattaruzza, Dominique Feillet, Maxime Ogier, Frédéric Semet. A heuristic branch-cut-and-price algorithm for the ROADEF/EURO challenge on Inventory Routing. Transportation Science, 2020, 54 (2), pp.299-564. ⟨10.1287/trsc.2019.0961⟩. ⟨emse-02163171⟩
226 Consultations
285 Téléchargements
