A new range-reduction algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computers Année : 2005
Range-reduction is a key point for getting accurate elementary function routines. We introduce a new algorithm that is fast for input arguments belonging to the most common domains, yet accurate over the full double-precision range.
Autre [cs.OH]
RangeReductionIEEETC0305.pdf (460.93 Ko) Télécharger le fichier
ensl-00086904 , version 1 (20-07-2006)
Jean-Michel Muller, Nicolas Brisebarre, Peter Kornerup, David Defour, Nathalie Revol. A new range-reduction algorithm. IEEE Transactions on Computers, 2005, 54 (3), pp.331- 339. ⟨10.1109/TC.2005.36⟩. ⟨ensl-00086904⟩
204 Consultations
1306 Téléchargements
