Reconfigurable arithmetic for HPC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
An often overlooked way to increase the efficiency of HPC on FPGA is to tailor, as tightly as possible, the arithmetic to the application. An ideally efficient implementation would, for each of its operations, toggle and transmit just the number of bits required by the application at this point. Conventional microprocessors, with their word-level granularity and fixed memory hierarchy, keep us away from this ideal. FPGAs, with their bit-level granularity, have the potential to get much closer. Therefore, reconfigurable computing should systematically investigate, in an application-specific way, non-standard precisions, but also non-standard number systems and non-standard arithmetic operations. The purpose of this chapter is to review these opportunities.
2012-Arith4HPC-chapter.pdf (262.93 Ko) Télécharger le fichier
ensl-00758377 , version 1 (28-11-2012)
  • HAL Id : ensl-00758377 , version 1
Florent de Dinechin, Bogdan Pasca. Reconfigurable arithmetic for HPC. Wim Vanderbauwhede and Khaled Benkrid. High-Performance Computing using FPGAs, Springer, 2013. ⟨ensl-00758377⟩
133 Consultations
370 Téléchargements
