A phase transition in the random transposition random walk - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2004
Our work is motivated by Bourque and Pevzner's (2002) simulation study of the effectiveness of the parsimony method in studying genome rearrangement, and leads to a surprising result about the random transposition walk on the group of permutations on $n$ elements. Consider this walk in continuous time starting at the identity and let $D_t$ be the minimum number of transpositions needed to go back to the identity from the location at time $t$.$D_t$ undergoes a phase transition: the distance $D_{cn/2} \sim u(c)n$, where $u$ is an explicit function satisfying $u(c)=c/2$ for $c \le 1$ and $u(c)1$. In other words, the distance to the identity is roughly linear during the subcritical phase, and after critical time $n/2$ it becomes sublinear.In addition, we describe the fluctuations of $D_{cn/2}$ about its mean in each of the threeregimes (subcritical, critical and supercritical). The techniques used involve viewing the cycles in the random permutation as a coagulation-fragmentation process and relating the behavior to the \Erd\H{o}s-Renyi random graph model.
rtrw0228.pdf (254.95 Ko) Télécharger le fichier
hal-00001309 , version 1 (16-03-2004)
hal-00001309 , version 2 (13-10-2004)
hal-00001309 , version 3 (12-08-2015)
Nathanael Berestycki, Rick Durrett. A phase transition in the random transposition random walk. 2004. ⟨hal-00001309v1⟩
407 Consultations
842 Téléchargements
