Structural relaxations around Ti, Cr and Fe impurities in alpha-Al2O3 probed by x-ray absorption near edge structure combined with first-principles calculations
Abstract : We determine the structural relaxations around paramagnetic impurities (Ti, Cr, Fe) in corundum (alpha-Al2O3), by combining x-ray absorption near edge structure (XANES) experiments and ab initio calculations. The structural relaxations are found to be very local. We then show that XANES is sensitive to small variations in interatomic distances within the coordination shell of the absorbing atom. The experiments were carried out on single crystals of ruby and sapphires. Linear dichroic signals are essential to characterize the geometry of the impurity site. The calculations were performed within a self-consistent ''non muffin-tin'' framework, that uses pseudopotentials, plane-wave basis set, and the continued fraction for the absorption cross section.
Type de document :
Article dans une revue
Journal of Physics: Condensed Matter, IOP Publishing, 2005, 17, pp.5467-5480. 〈10.1088/0953-8984/17/36/003〉
Liste complète des métadonnées
Littérature citée [22 références]  Voir  Masquer  Télécharger
https://hal.archives-ouvertes.fr/hal-00003882
Contributeur : Delphine Cabaret <>
Soumis le : mercredi 12 janvier 2005 - 17:44:12
Dernière modification le : vendredi 4 janvier 2019 - 17:33:01
Document(s) archivé(s) le : jeudi 1 avril 2010 - 16:21:30
Collections
Citation
Emilie Gaudry, Delphine Cabaret, Philippe Sainctavit, Christian Brouder, Francesco Mauri, et al.. Structural relaxations around Ti, Cr and Fe impurities in alpha-Al2O3 probed by x-ray absorption near edge structure combined with first-principles calculations. Journal of Physics: Condensed Matter, IOP Publishing, 2005, 17, pp.5467-5480. 〈10.1088/0953-8984/17/36/003〉. 〈hal-00003882〉
Métriques
Consultations de la notice
499
Téléchargements de fichiers
227
