XANES Calculation with an Efficient “Non Muffin-Tin” Method : Application to the Angular Dependence of the AI K-Edge in Corundum.
Abstract : We present a reciprocal-space “non muffin-tin” scheme for calculating X-ray Absorption Near-Edge Structure (XANES). The method uses pseudopotentials and reconstructs all electronwave functions within the ProjectorAugmentedWave framework. The method incorporates a recursive method to compute absorption cross section as a continued fraction. The continued fraction formulation of absorption is advantageous in that it permits the treatment of core-hole-electron interaction through large supercells (hundreds of atoms). This opens new fields of applications like surfaces, molecules, small aggregates or amorphous materials, for which large supercells are required. The method is applied to the natural linear dichroism at theAl K-edge in corundum (-Al2O3). Details about the convergence process of the calculation are given. The influence of the core-hole effects is emphasized and comparison with “muffin-tin” multiple scattering calculation is made.
Type de document :
Article dans une revue
Physica Scripta, IOP Publishing, 2005, 115, pp.131-133
Liste complète des métadonnées
https://hal.archives-ouvertes.fr/hal-00021941
Contributeur : Sylvia Deplanque <>
Soumis le : mercredi 29 mars 2006 - 15:54:04
Dernière modification le : jeudi 11 janvier 2018 - 06:20:20
  • HAL Id : hal-00021941, version 1
Collections
Citation
Delphine Cabaret, Emilie Gaudry, Mathieu Taillefumier, Philippe Sainctavit, Francesco Mauri. XANES Calculation with an Efficient “Non Muffin-Tin” Method : Application to the Angular Dependence of the AI K-Edge in Corundum.. Physica Scripta, IOP Publishing, 2005, 115, pp.131-133. 〈hal-00021941〉
Métriques
Consultations de la notice
81
