Cosmic Background of Gravitational Waves from Rotating Neutron Stars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Astronomy and Astrophysics - A&A Année : 2001
The extragalactic background of gravitational waves produced by tri-axial rotating neutron stars was calculated, under the assumption that the properties of the underlying pulsar population are the same of those of the galactic population, recently derived by Regimbau & de Freitas Pacheco (2000). For an equatorial ellipticity of $\epsilon$ = 10$^{-6}$, the equivalent density parameter due to gravitational waves has a maximum amplitude in the range 2$\times10^{-11}-3\times10^{-9}$, around 0.9-1.5 kHz. The main reasons affecting the theoretical predictions are discussed. This background is comparable to that produced by the ''ring-down'' emission from distorted black holes. The detection possibility of this background by a future generation of gravitational antennas is also examined.
aa1424.pdf (161.96 Ko) Télécharger le fichier
hal-00107280 , version 1 (24-01-2021)
Tania Regimbau, Jose Antonio de Freitas Pacheco. Cosmic Background of Gravitational Waves from Rotating Neutron Stars. Astronomy and Astrophysics - A&A, 2001, 376, pp.381. ⟨10.1051/0004-6361:20011005⟩. ⟨hal-00107280⟩
150 Consultations
51 Téléchargements
