A Generic Library for Floating-Point Numbers and Its Application to Exact Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Marc Daumas
  • Fonction : Auteur
  • PersonId : 832231
Laurence Rideau
  • Fonction : Auteur
  • PersonId : 832430
Laurent Thery
In this paper we present a general library to reason about floating-point numbers within the Coq system. Most of the results of the library are proved for an arbitrary floating-point format and an arbitrary base. A special emphasis has been put on proving properties for exact computing, i.e. computing without rounding errors.
DauRidThe01.pdf (227.6 Ko) Télécharger le fichier
hal-00157285 , version 1 (25-06-2007)
  • HAL Id : hal-00157285 , version 1
Marc Daumas, Laurence Rideau, Laurent Thery. A Generic Library for Floating-Point Numbers and Its Application to Exact Computing. Theorem Proving in Higher Order Logics, 2001, Edinburgh, United Kingdom. pp.169-184. ⟨hal-00157285⟩
269 Consultations
622 Téléchargements
