Model Reduction of Chemical Reaction Systems using Elimination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
There exist different schemes of model reduction for parametric ordinary differential systems arising from chemical reaction systems. In this paper, we focus on some schemes which rely on quasi-steady states approximations. We show that these schemes can be formulated by means of differential and algebraic elimination. Our formulation is simpler than the classical ones. It permitted us to obtain an approximation of the basic enzymatic reaction system which is different from those of Henri-Michaëlis-Menten and Briggs-Haldane.
bllm-macis-2007.pdf (205.93 Ko) Télécharger le fichier
hal-00184558 , version 1 (31-10-2007)
  • HAL Id : hal-00184558 , version 1
François Boulier, Marc Lefranc, François Lemaire, Pierre-Emmanuel Morant. Model Reduction of Chemical Reaction Systems using Elimination. 2007. ⟨hal-00184558⟩
447 Consultations
345 Téléchargements
