Message-embedding from a control-theoretical point of view
Abstract : Many encryption methods involving chaotic dynamics have been proposed in the literature since the early 90's. Most of them mask the confidential information being transmitted through an insecure channel, with a chaotic analog or digital sequence. The recovering of the original information usually calls for reproducing, at the receiver side, the same chaotic signal as at the transmitter side. The synchronization mechanism of the two chaotic signals is known as chaos synchronization. In this communication, a connection between chaotic and conventional encryption is established via the control-theoretical condition of flatness, with special emphasis on one of the most attractive schemes, namely, message-embedding. The main conclusion can be stated as follows: the message-embedded cryptosystem is equivalent to a conventional self-synchronizing stream cipher under the flatness condition. It follows that both architectures have the same level of security
Type de document :
Communication dans un congrès
4th congreso ibericoamericano de seguridad informatica, CIBSI'07, Nov 2007, Buenos Aires, Argentina. pp.CDROM, 2007
Liste complète des métadonnées
https://hal.archives-ouvertes.fr/hal-00200342
Contributeur : Gilles Millerioux <>
Soumis le : jeudi 20 décembre 2007 - 16:32:23
Dernière modification le : mercredi 18 mai 2016 - 08:56:39
Document(s) archivé(s) le : jeudi 27 septembre 2012 - 12:05:15
Fichier
CIBSI070729.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-00200342, version 1
Collections
Citation
Gilles Millérioux, Jose Maria Amigo, Jamal Daafouz. Message-embedding from a control-theoretical point of view. 4th congreso ibericoamericano de seguridad informatica, CIBSI'07, Nov 2007, Buenos Aires, Argentina. pp.CDROM, 2007. <hal-00200342>
Métriques
Consultations de
la notice
164
Téléchargements du document
63
