Insight into electronic mechanisms of nanosecond-laser ablation of silicon - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Physics Année : 2008
We present experimental and theoretical studies of nanosecond ArF excimer laser desorption and ablation of silicon with insight into material removal mechanisms. The experimental studies involve a comprehensive analysis of the laser-induced plume dynamics and measurements of the charge gained by the target during irradiation time. At low laser fluences, well below the melting threshold, high-energy ions with a narrow energy distribution are observed. When the fluence is increased, a thermal component of the plume is formed superimposing on the nonthermal ions, which are still abundant. The origin of these ions is discussed on the basis of two modeling approaches, thermal and electronic, and we analyze the dynamics of silicon target excitation, heating, melting, and ablation. An electronic model is developed that provides insight into the charge-carrier transport in the target. We demonstrate that, contrary to a commonly accepted opinion, a complete thermalization between the electron and lattice subsystems is not reached during the nanosecond-laser pulse action. Moreover, the charging effects can retard the melting process and have an effect on the overall target behavior and laser-induced plume dynamics.
2008-JAP-Marine.pdf (558.09 Ko) Télécharger le fichier
2008-JAP-Marine-erratum.pdf (39.55 Ko) Télécharger le fichier
hal-00303806 , version 1 (19-10-2017)
Wladimir Marine, N.M. Bulgakova, Lionel Patrone, Igor Ozerov. Insight into electronic mechanisms of nanosecond-laser ablation of silicon. Journal of Applied Physics, 2008, 103, pp.094902. ⟨10.1063/1.2903527⟩. ⟨hal-00303806⟩
140 Consultations
318 Téléchargements
