Journal articles
Filtering for distributed mechanical systems using position measurements: perspectives in medical imaging
Abstract : We propose an effective filtering methodology designed to perform estimation in a distributed mechanical system using position measurements. As in a previously introduced method, the filter is inspired from robust control feedback, but here we take full advantage of the estimation specificity to choose a feedback law that can act on displacements instead of velocities and still retain the same kind of dissipativity property which guarantees robustness. This is very valuable in many applications for which positions are more readily available than velocities, as in medical imaging. We provide an in-depth analysis of the proposed procedure, as well as detailed numerical assessments using a test problem inspired from cardiac biomechanics, as medical diagnosis assistance is an important perspective for this approach. The method is formulated first for measurements based on Lagrangian displacements, but we then derive a nonlinear extension allowing to instead consider segmented images, which of course is even more relevant in medical applications.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-00358914
Contributor : Dominique Chapelle <>
Submitted on : Wednesday, June 5, 2013 - 2:35:05 PM
Last modification on : Thursday, September 24, 2020 - 4:00:22 PM
Long-term archiving on: : Tuesday, January 3, 2017 - 5:36:13 PM
File
PM_DC_PLT.pdf
Identifiers
Citation
Philippe Moireau, Dominique Chapelle, Patrick Le Tallec. Filtering for distributed mechanical systems using position measurements: perspectives in medical imaging. Inverse Problems, IOP Publishing, 2009, 25 (3), pp.++. ⟨10.1088/0266-5611/25/3/035010⟩. ⟨hal-00358914⟩
Share
Metrics
Record views
861
Files downloads
509
