Minimizing within convex bodies using a convex hull method
We present numerical methods to solve optimization problems on the space of convex functions or among convex bodies. Hence convexity is a constraint on the admissible objects, whereas the functionals are not required to be convex.To deal with, our method mix geometrical and numerical algorithms. We give several applications arising from classical problems in geometry and analysis: Alexandrov's problem of finding a convex body of prescribed surface function; Cheeger's problem of a subdomain minimizing the ratio surface area on volume; Newton's problem of the body of minimal resistance. In particular for the latter application, the minimizers are still unknown, except in some particular classes. We give approximate solutions better than the theoretical known ones, hence demonstrating that the minimizers do not belong to these classes.
