Reachability and minimal times for state constrained nonlinear problems without any controllability assumption - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2010
We consider a target problem for a nonlinear system under state constraints. We give a new continuous level-set approach for characterizing the optimal times and the backward-reachability sets. This approach leads to a characterization via a Hamilton-Jacobi equation, without assuming any controllability assumption. We also treat the case of time-dependent state constraints, as well as a target problem for a two-player game with state constraints. Our method gives a good framework for numerical approximations, and some numerical illustrations are included in the paper.
BFZ-Obstacle.pdf (1.19 Mo) Télécharger le fichier
hal-00395589 , version 1 (15-06-2009)
  • HAL Id : hal-00395589 , version 1
Olivier Bokanowski, Nicolas Forcadel, Hasnaa Zidani. Reachability and minimal times for state constrained nonlinear problems without any controllability assumption. SIAM Journal on Control and Optimization, 2010, 48 (7), pp. 4292-4316. ⟨hal-00395589⟩
573 Consultations
650 Téléchargements
