HyperLogLog: the analysis of a near-optimal cardinality estimation algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This extended abstract describes and analyses a near-optimal probabilistic algorithm, HYPERLOGLOG , dedicated to estimating the number of distinct elements (the cardinality) of very large data ensembles. Using an auxiliary memory of m units (typically, “short bytes”), HYPERLOGLOG performs a single pass over the data and produces an estimate of the cardinality such that the relative accuracy (the standard error) is typically about 1.04/√m. This improves on the best previously known cardinality estimator, LOGLOG, whose accuracy can be matched by consuming only 64% of the original memory. For instance, the new algorithm makes it possible to estimate cardinalities well beyond 10^9 with a typical accuracy of 2% while using a memory of only 1.5 kilobytes. The algorithm parallelizes optimally and adapts to the sliding window model.
FlFuGaMe07.pdf (396.64 Ko) Télécharger le fichier
hal-00406166 , version 1 (21-07-2009)
hal-00406166 , version 2 (17-08-2015)
  • HAL Id : hal-00406166 , version 1
Philippe Flajolet, Eric Fusy, Olivier Gandouet, Frédéric Meunier. HyperLogLog: the analysis of a near-optimal cardinality estimation algorithm. Analysis of Algorithms 2007 (AofA07), Jun 2007, Juan les pins, France. pp.127--146. ⟨hal-00406166v1⟩
31870 Consultations
7804 Téléchargements
