Optimal Control of Second-Order Linear Systems with Fixed Proportional-Integral Structure Controller
Abstract : This paper proposes a new semi-analytic robust mixed H2/H-infinity design method for fixed-structure controllers. Precisely, the method consists in determining the parameters of a given structure controller that minimizes the influence of a step load disturbance to the process output with the respect of robustness constraints, i.e. constraints on maximum amplification of measurement noise, minimum module margin and minimum phase margin. The design objective and the robustness constraints are expressed as H2 and H-infinity norms in function of unknown controller parameters. The controller design problem is then reformulated into a nonlinear optimization problem with a set of inequality constraints that can be efficiently solved numerically. Finally, we obtain a controller design tool which provides, when it exists, an optimal controller that fulfills the design specifications. Furthermore, the proposed method enables also a graphical representation of the different design tradeoffs. In this paper, to demonstrate the results, this method is applied to second-order processes controlled by PI controller
Type de document :
Communication dans un congrès
European Control Conference, ECC'2009, Aug 2009, Budapest, Hungary. pp. 2566- 2571, 2009
Liste complète des métadonnées
https://hal.archives-ouvertes.fr/hal-00424763
Contributeur : Eduardo Mendes <>
Soumis le : vendredi 16 octobre 2009 - 22:45:58
Dernière modification le : lundi 21 mars 2016 - 17:27:15
  • HAL Id : hal-00424763, version 1
Collections
Citation
Hoang Bao Le, Eduardo Mendes. Optimal Control of Second-Order Linear Systems with Fixed Proportional-Integral Structure Controller. European Control Conference, ECC'2009, Aug 2009, Budapest, Hungary. pp. 2566- 2571, 2009. <hal-00424763>
Métriques
Consultations de la notice
47
