Measurement of the laser relative intensity noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This article describes the measurement of the RIN power spectral density with the cross-spectrum method. Averaging the cross spectrum of two equal and independent channels that measure the same beam, the instrument background is not limited by the single-channel noise. Additionally, the measure can be validated on the basis of simple mathematical properties. This removes the need of a low-noise beam to validate the instrument background, which is a relevant experimental limitation of the (traditional) single-channel method.
Rubiolat2009.pdf (161.15 Ko) Télécharger le fichier
hal-00472299 , version 1 (14-04-2021)
Paternité
E. Rubiola, K. Volyanskiy, L. Larger. Measurement of the laser relative intensity noise. 23rd European Frequency and Time Forum/IEEE International Frequency Control Symposium, Apr 2009, Besançon, France. pp.50-53, ⟨10.1109/FREQ.2009.5168140⟩. ⟨hal-00472299⟩
183 Consultations
1373 Téléchargements
