Abstract : The growing needs in computational power to answer to the increasing number of on-line services and the complexity of applications makes it mandatory to build corresponding hardware infrastructures and to share several distributed hardware and software resources thanks to grid computing. To help with optimizing resource utilization, system virtualization is a more and more adopted technique in data centers. However, this software layer adds to the administration complexity of servers and it requires specific management tools to deal with hypervisor functionalities like live migration. To address this problem, we propose VMScript, a domain specific language for administration of virtualized grid infrastructures. This language relies on set manipulation and is used to introspect physical and virtual grid architectures thanks to query expressions and notably to modify VM placement on machines.
https://hal.inria.fr/hal-00474647 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, September 5, 2014 - 11:15:33 AM Last modification on : Wednesday, April 27, 2022 - 4:22:51 AM Long-term archiving on: : Friday, April 14, 2017 - 4:13:18 PM
Rémy Pottier, Marc Léger, Jean-Marc Menaud. A Reconfiguration Language for Virtualized Grid Infrastructures. 10th IFIP WG 6.1 International Conference on Distributed Applications and Interoperable Systems (DAIS) / Held as part of International Federated Conference on Distributed Computing Techniques (DisCoTec), Jun 2010, Amsterdam, Netherlands. pp.42-55, ⟨10.1007/978-3-642-13645-0_4⟩. ⟨hal-00474647v2⟩
