Solving Cauchy problems by minimizing an energy-like functional, Inverse Problems, vol.22, issue.1, pp.115-133, 2006. ,
DOI : 10.1088/0266-5611/22/1/007
URL : https://hal.archives-ouvertes.fr/hal-00139569
Data completion via an energy error functional, Comptes Rendus M??canique, vol.333, issue.2, pp.171-177, 2005. ,
DOI : 10.1016/j.crme.2004.10.005
URL : https://hal.archives-ouvertes.fr/hal-00086964
On Cauchy's problem: II. Completion, regularization and approximation, Inverse Problems, vol.22, issue.4, pp.1307-1336, 2006. ,
DOI : 10.1088/0266-5611/22/4/012
Topological sensitivity analysis for the location of small cavities in stokes flows, SIAM J. Cont. Opt, 2009. ,
On Cauchy's problem : I. A variational Steklov-Poincaré theory, Inverse Problems, vol.21, pp.1915-1936, 2005. ,
Numerical Simulation and Optimal Control in Plasma Physics with Applications to Tokamaks, Series in Modern Applied Mathematics, 1989. ,
Inverse problems in elasticity, Inverse Problems, vol.21, issue.2, 2005. ,
DOI : 10.1088/0266-5611/21/2/R01
URL : https://hal.archives-ouvertes.fr/hal-00111264
A quasi-reversibility approach to solve the inverse obstacle problem, Inverse Problems and Imaging, vol.4, issue.3, pp.351-377, 2010. ,
DOI : 10.3934/ipi.2010.4.351
URL : https://hal.archives-ouvertes.fr/hal-00873059
The interpretation of tokamak magnetic diagnostics, Plasma Physics and Controlled Fusion, vol.33, issue.7, pp.715-748, 1991. ,
DOI : 10.1088/0741-3335/33/7/001
Identification of Robin coefficients by the means of boundary measurements, Inverse Problems, vol.15, issue.6, p.1425, 1999. ,
DOI : 10.1088/0266-5611/15/6/303
The Finite Element Method For Elliptic Problems, 1980. ,
Fast control of the plasma surface, Computer Physics Communications, vol.31, issue.2-3, pp.143-148, 1984. ,
DOI : 10.1016/0010-4655(84)90041-9
Approximation dans des classes de fonctions analytiques généralisées et résolution de problèmes inverses pour les tokamaks, 2011. ,
Some inverse problems around the tokamak <em>Tore Supra</em>, Communications on Pure and Applied Analysis, vol.11, issue.6 ,
DOI : 10.3934/cpaa.2012.11.2327
Hydromagnetic equilibria and force-free fields, 2nd U.N. Conference on the Peaceful uses of Atomic Energy, pp.190-197, 1958. ,
DOI : 10.1016/0891-3919(58)90139-6
Modélisation de l'équilibre d'un plasma de tokamak -Tokamak plasma equilibrium modelling, 1999. ,
Conformal mappings and inverse boundary value problems, Inverse Problems, vol.21, issue.3, pp.935-953, 2005. ,
DOI : 10.1088/0266-5611/21/3/009
URL : https://hal.archives-ouvertes.fr/hal-00744137
Rank-Deficient and Discrete Ill-Posed Problems : Numerical Aspects of Linear Inversion, SIAM, 1998. ,
DOI : 10.1137/1.9780898719697
Numerical implementation of a variational method for electrical impedance tomography, Inverse Problems, vol.6, issue.3, p.389, 1990. ,
DOI : 10.1088/0266-5611/6/3/009
Determining conductivity by boundary measurements II. Interior results, Communications on Pure and Applied Mathematics, vol.56, issue.5, pp.643-667, 1985. ,
DOI : 10.1002/cpa.3160380513
Relaxation of a variational method for impedance computed tomography, Communications on Pure and Applied Mathematics, vol.34, issue.6, pp.745-777, 1987. ,
DOI : 10.1002/cpa.3160400605
Computation of ideal MHD equilibria, Computer Physics Communications, vol.12, issue.1, pp.33-44, 1976. ,
DOI : 10.1016/0010-4655(76)90008-4
Error Estimate Procedure in the Finite Element Method and Applications, SIAM Journal on Numerical Analysis, vol.20, issue.3, pp.485-509, 1983. ,
DOI : 10.1137/0720033
Contrôle optimal de systèmes gouvernés par des équations aux dérivées partielles (Optimal control of systems governed by partial differential equations), 1968. ,
Local expansion method for fast plasma boundary identification in JET, Nuclear Fusion, vol.33, issue.3, pp.467-474, 1993. ,
DOI : 10.1088/0029-5515/33/3/I08
Domain Decomposition Methods for Partial Differential Equations, 1999. ,
Real time determination and control of the plasma localisation and internal inductance in Tore Supra, Fusion Engineering and Design, vol.56, issue.57, pp.56-57761, 2001. ,
DOI : 10.1016/S0920-3796(01)00399-4
JET real-time object-oriented code for plasma boundary reconstruction, Fusion Engineering and Design, vol.66, issue.68, pp.66-68735, 2003. ,
DOI : 10.1016/S0920-3796(03)00290-4
On magnetohydrodynamical equilibrium configurations, Soviet Physics JETP, vol.6, issue.3, p.1013, 1958. ,
Use of the virtual-casing principle in calculating the containing magnetic field in toroidal plasma systems, Nuclear Fusion, vol.12, issue.5, pp.599-601, 1972. ,
DOI : 10.1088/0029-5515/12/5/009
Tokamaks, volume 118 of International Series of Monographs on Physics, 2004. ,
