Using vector divisions in solving the linear complementarity problem
Abstract : The linear complementarity problem LCP(M,q) is to find a vector z in IRⁿ satisfying z^{T}(Mz+q)=0, Mz+q≥0, z≥0, where M=(m_{ij})∈IR^{n×n} and q∈IRⁿ are given. In this paper, we use the fact that solving LCP(M,q) is equivalent to solve the nonlinear equation F(x)=0 where F is a function from IRⁿ into itself defined by F(x)=(M+I)x+(M-I)|x|+q. We build a sequence of smooth functions F(p,x) uniformly convergent to the function F(x). We show that, an approximation of the solution of the LCP(M,q) (when it exists) is obtained by solving F(p,x)=0 for a parameter p large enough. Then we give a globally convergent hybrid algorithm based on vector divisions and the secant method for solving the LCP(M,q). We close our paper with some numerical simulation to illustrate our theoretical results, and to show that this method can solve efficiently large-scale linear complementarity problems.
Type de document :
Pré-publication, Document de travail
2010
Liste complète des métadonnées
https://hal.archives-ouvertes.fr/hal-00482110
Contributeur : Youssef El Foutayeni <>
Soumis le : samedi 8 mai 2010 - 17:47:56
Dernière modification le : lundi 21 mars 2016 - 11:30:22
Document(s) archivé(s) le : jeudi 16 septembre 2010 - 13:21:29
Fichiers
LCPusingVectorDivisions.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-00482110, version 1
  • ARXIV : 1005.1417
Collections
Citation
Youssef Elfoutayeni, Mohamed Khaladi. Using vector divisions in solving the linear complementarity problem. 2010. <hal-00482110>
Métriques
Consultations de
la notice
208
Téléchargements du document
99
