Khatri-Rao space-time codes, IEEE Transactions on Signal Processing, vol.50, issue.10, pp.2396-2407, 2002. ,
DOI : 10.1109/TSP.2002.803341
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.163.4214
Multi-User MISO Broadcast Channel with User-Cooperating Decoder, 2008 IEEE 68th Vehicular Technology Conference, pp.1-5, 2008. ,
DOI : 10.1109/VETECF.2008.335
Blind identification of MISO-FIR channels, Signal Processing, vol.90, issue.2, pp.490-503, 2010. ,
DOI : 10.1016/j.sigpro.2009.07.023
URL : https://hal.archives-ouvertes.fr/hal-00420044
Foundation of the PARAFAC procedure: models and conditions for an " explanatory " multimodal factor analysis, UCLA working papers in phonetics, vol.16, pp.1-84, 1970. ,
Blind PARAFAC receivers for DS-CDMA systems, IEEE Transactions on Signal Processing, vol.48, issue.3, pp.810-823, 2000. ,
DOI : 10.1109/78.824675
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.141.1676
PARAFAC-based unified tensor modeling for wireless communication systems with application to blind multiuser equalization, Signal Processing, vol.87, issue.2, pp.337-351, 2007. ,
DOI : 10.1016/j.sigpro.2005.12.014
URL : https://hal.archives-ouvertes.fr/hal-00417636
An enhanced line search scheme for complex-valued tensor decompositions. Application in DS-CDMA, Signal Processing, vol.88, issue.3, pp.749-755, 2008. ,
DOI : 10.1016/j.sigpro.2007.07.024
Enhanced Line Search: A Novel Method to Accelerate PARAFAC, SIAM Journal on Matrix Analysis and Applications, vol.30, issue.3, pp.1148-1171, 2008. ,
DOI : 10.1137/06065577
URL : https://hal.archives-ouvertes.fr/hal-00327595
Blind equalization of nonlinear channels using a tensor decomposition with code/space/time diversities, Signal Processing, vol.89, issue.2, pp.133-143, 2009. ,
DOI : 10.1016/j.sigpro.2008.07.016
URL : https://hal.archives-ouvertes.fr/hal-00417609
The Volterra and Wiener theories of nonlinear systems, 1980. ,
Identification of Parallel-Cascade Wiener Systems Using Joint Diagonalization of Third-Order Volterra Kernel Slices, IEEE Signal Processing Letters, vol.16, issue.3, pp.188-191, 2009. ,
DOI : 10.1109/LSP.2008.2011706
URL : https://hal.archives-ouvertes.fr/hal-00417584
Tensor Decompositions and Applications, SIAM Review, vol.51, issue.3, pp.455-500, 2009. ,
DOI : 10.1137/07070111X
Parallel factor analysis in sensor array processing, IEEE Transactions on Signal Processing, vol.48, issue.8, pp.2377-2388, 2000. ,
DOI : 10.1109/78.852018
A fast algorithm for joint diagonalization with non-orthogonal transformations and its application to blind source separation, Journal of Machine Learning Research, vol.5, pp.777-800, 2004. ,
