Optimal control models of the goal-oriented human locomotion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2012
Yacine Chitour
Frédéric Jean
Paolo Mason
In recent papers it has been suggested that human locomotion may be modeled as an inverse optimal control problem. In this paradigm, the trajectories are assumed to be solutions of an optimal control problem that has to be determined. We discuss the modeling of both the dynamical system and the cost to be minimized, and we analyze the corresponding optimal synthesis. The main results describe the asymptotic behavior of the optimal trajectories as the target point goes to infinity.
locomotion-submitted.pdf (346.34 Ko) Télécharger le fichier
hal-00493444 , version 1 (18-06-2010)
Yacine Chitour, Frédéric Jean, Paolo Mason. Optimal control models of the goal-oriented human locomotion. SIAM Journal on Control and Optimization, 2012, 50 (1), pp.147-170. ⟨10.1137/100799344⟩. ⟨hal-00493444⟩
251 Consultations
233 Téléchargements
