Global chassis control -integration of chassis systems, Automatisierungstechnik, vol.51, pp.300-312, 2003. ,
A convex characterization of gain-scheduled H/sub ???/ controllers, IEEE Transactions on Automatic Control, vol.40, issue.5, pp.853-864, 1995. ,
DOI : 10.1109/9.384219
Robust control of anti-lock brake system, Vehicle System Dynamics, vol.127, issue.3, pp.217-232, 2007. ,
DOI : 10.1076/vesd.39.2.81.14159
Dynamic Modeling of Magnetorheological Damper Behaviors, Journal of Intelligent Material Systems and Structures, vol.6, issue.2, pp.3-14, 2006. ,
DOI : 10.1177/1045389X06055860
Rollover Stability Index Including Effects of Suspension Design, SAE Technical Paper Series, pp.2002-2003, 2002. ,
DOI : 10.4271/2002-01-0965
Robust H/sub 2/ optimal control of an active suspension, Proceedings of the 1997 IEEE International Conference on Control Applications, pp.761-766, 1997. ,
DOI : 10.1109/CCA.1997.627751
Minimizing the frequency in a black box model of a mr damper, 11th Mini Conf on Vehicle Sys. Dyn., Ident. and Anomalies, 2008. ,
Robust Multivariable Linear Parameter Varying Automotive Global Chassis Control, Control System dpt, 2008. ,
OPTIMAL SKYHOOK CONTROL FOR SEMI-ACTIVE SUSPENSIONS, Proceedings of the 4th IFAC Symposium on Mechatronics Systems, pp.608-613, 2006. ,
DOI : 10.3182/20060912-3-DE-2911.00106
URL : https://hal.archives-ouvertes.fr/hal-00083420
A new semi-active suspension control strategy through LPV technique, Control Engineering Practice, vol.16, issue.12, pp.1519-1534, 2008. ,
DOI : 10.1016/j.conengprac.2008.05.002
URL : https://hal.archives-ouvertes.fr/hal-00316520
Skyhook and H8 Control of Semi-active Suspensions: Some Practical Aspects, Vehicle System Dynamics, vol.39, issue.4, pp.279-308, 2003. ,
DOI : 10.1076/vesd.39.4.279.14149
Mixed Sky-Hook and ADD: Approaching the Filtering Limits of a Semi-Active Suspension, Journal of Dynamic Systems, Measurement, and Control, vol.129, issue.4, pp.382-392, 2007. ,
DOI : 10.1115/1.2745846
Mixed Slip-Deceleration Control in Automotive Braking Systems, Journal of Dynamic Systems, Measurement, and Control, vol.129, issue.1, pp.20-31, 2007. ,
DOI : 10.1115/1.2397149
Multiobjective output-feedback control via LMI optimization, IEEE Transactions on Automatic Control, vol.42, issue.7, pp.896-911, 1997. ,
DOI : 10.1109/9.599969
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.42.5458
Robust automotive suspension control toward global chassis control, INPG, Laboratoire d'Automatique de Grenoble (new GIPSA-lab), 2005. ,
A nonlinear vehicle bicycle model for suspension and handling control studies, Proceedings of the IFAC Conference on Advances in Vehicle Control and Safety (AVCS), pp.638-643, 2004. ,
