Localization for the random displacement model
Abstract : We prove spectral and dynamical localization for the multi-dimensional random displacement model near the bottom of its spectrum by showing that the approach through multiscale analysis is applicable. In particular, we show that a previously known Lifshitz tail bound can be extended to our setting and prove a new Wegner estimate. A key tool is given by a quantitative form of a property of a related single-site Neumann problem which can be described as ''bubbles tend to the corners''.
Type de document :
Pré-publication, Document de travail
Corrected typos and improved some arguments. 2011
Liste complète des métadonnées
https://hal.archives-ouvertes.fr/hal-00499598
Contributeur : Frédéric Klopp <>
Soumis le : lundi 13 juin 2011 - 21:22:02
Dernière modification le : mardi 11 octobre 2016 - 14:53:04
Document(s) archivé(s) le : mercredi 14 septembre 2011 - 02:23:27
Fichiers
KLNS_June132011.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-00499598, version 3
  • ARXIV : 1007.2483
Collections
Citation
Frédéric Klopp, Michael Loss, Shu Nakamura, Gunter Stolz. Localization for the random displacement model. Corrected typos and improved some arguments. 2011. <hal-00499598v3>
Métriques
Consultations de
la notice
309
Téléchargements du document
70
