Passing to the limit 2D-1D in a model for metastatic growth - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Biological Dynamics Année : 2011
We prove the convergence of a family of solutions to a two-dimensional transport equation with a nonlocal boundary condition modeling the evolution of a population of metastases. We show that when the data of the repartition along the boundary tends to a dirac mass then the solution of the associated problem converges and we derive a simple expression for the limit in term of the solution of a 1D equation. This result permits to improve the computational time needed to simulate the model.
Caract_eps_pspdftex.pdf (19.36 Ko) Télécharger le fichier
Limite2D1D_HAL.pdf (199.64 Ko) Télécharger le fichier
hal-00521968 , version 1 (29-09-2010)
Sebastien Benzekry. Passing to the limit 2D-1D in a model for metastatic growth. Journal of Biological Dynamics, 2011, pp.10.1080/17513758.2011.568071. ⟨10.1080/17513758.2011.568071⟩. ⟨hal-00521968⟩
175 Consultations
149 Téléchargements
