Symplectic schemes for highly oscillatory Hamiltonian systems with varying fast frequencies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes rendus de l'Académie des sciences. Série I, Mathématique Année : 2010
We derive symplectic integrators for a class of highly oscillatory Hamiltonian systems. Our approach is based upon a two-scale expansion of the solution to the Hamilton-Jacobi equation associated to the original dynamics. This Note presents an extension of the approach previously introduced in Le Bris and Legoll (2007, 2010) to the case where the fast frequencies of the system, instead of being constant, explicitly depend on the slow degrees of freedom.
hal-00524816 , version 1 (08-10-2010)
Matthew Dobson, Claude Le Bris, Frédéric Legoll. Symplectic schemes for highly oscillatory Hamiltonian systems with varying fast frequencies. Comptes rendus de l'Académie des sciences. Série I, Mathématique, 2010, 348 (17-18), pp.1033-1038. ⟨10.1016/j.crma.2010.08.005⟩. ⟨hal-00524816⟩
167 Consultations
0 Téléchargements
