An evaluation of uncertainties in monitoring middle atmosphere temperatures with the ground-based lidar network in support of space observations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Atmospheric and Solar-Terrestrial Physics Année : 2011
The capability of the longest lidar data sets to monitor long-term temperature changes have been evaluated through comparisons with the successive Stratospheric Sounder Units (SSU) onboard NOAA satellites. Cross-consistency investigations between SSU and the lidar network can be considered as a first attempt to demonstrate how the synergistic use of space and ground-based instruments could provide reliable monitoring of the temperature of the middle atmosphere. The breakdown of the temperature cooling trend, and the following flattening observed in the satellite temperature series, are qualitatively confirmed by the lidars. However, there are still large differences that can either be due to SSU continuity (orbit drifts or weighting function modifications) or lidar operation changes (time of measurements, accuracy, sampling, etc.). SSU vertical weighting functions have been taken into account for comparisons. Some discontinuity events cannot be explained by the SSU weighting function drifts due to CO2. For the upper channels of SSU (peaking around 50 km) the results are probably sensitive to the mesospheric part of the lidar profiles that can explain some discontinuities. Tropical lidar stations show clear inter-annual differences with the SSU channels covering the lowest altitude range that need further investigations to understand if the origin is instrumental or geophysical. An attempt to derive non-linear trends with combinations of linear, hockey stick, and quadratic functions has been made. While the quadratic term is not highly significant, this approach allows the derivation of a better quantification of the linear trend terms.
Keckhut et al, JASTP 2011_hal.pdf (1.72 Mo) Télécharger le fichier
hal-00560268 , version 1 (25-10-2016)
Philippe Keckhut, W. J. Randel, Chantal Claud, Thierry Leblanc, Wolfgang Steinbrecht, et al.. An evaluation of uncertainties in monitoring middle atmosphere temperatures with the ground-based lidar network in support of space observations. Journal of Atmospheric and Solar-Terrestrial Physics, 2011, 73 (5-6), pp.627-642. ⟨10.1016/j.jastp.2011.01.003⟩. ⟨hal-00560268⟩
877 Consultations
130 Téléchargements
