Macroscopic drive chain efficiency modeling using state machines, 17th IFAC World Congress, pp.2294-2299, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00293358
Irreversibility modeling applied to the control of complex robotic drive chains. 4th ICINCO, Angers, pp.217-222, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00258553
Modelling, design, and control of flexible manipulators arms: status and trends, NASA Conference on Space Telerobotics, vol.3, pp.11-24, 1989. ,
Linear controller design. Limits of performance, 1991. ,
Linear matrix inequalities in system and control theory, 1994. ,
Model predictive control, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00256633
A multiobjective control via Youla parameterization and LMI optimization: application to a flexible arm, IFAC Symposium on Robust Control and Design, 2000. ,
Robustness with observers, In IEEE Trans. Automatic Control, vol.24, pp.607-611, 1979. ,
LPV controller design for robot manipulators based on augmented LMI conditions with structural constraints, IFAC Symposium on System, Structure and Control, 2010. ,
Feedback nonlinear predictive control of rigid link robot manipulators, IEEE ACC, pp.3594-3599, 2002. ,
Closed loop stability of discrete linear single variable systems, Kybernetika, vol.10, issue.2, pp.146-171, 1974. ,
Improving the robustness of a parallel robot using Predictive Functional Control (PFC) tools, 45th IEEE CDC, pp.6468-6473, 2006. ,
Predictive control with constrains, 2001. ,
Multivariable feedback design, 1989. ,
Generalized predictive control for single-link flexible joint robot, International Journal on Sciences and Techniques of Automatic Control, vol.3, issue.1, pp.890-899, 2009. ,
On output feedback tracking control of robot manipulators with bounded torque input, International Journal of Control, Automation, and Systems, vol.6, issue.1, pp.76-85, 2008. ,
Modelling and control of robot, 1996. ,
An efficient solution to multiobjective control problem with LMI objectives, Systems and Control Letters, vol.40, pp.43-57, 2000. ,
Robot modeling and control, 2005. ,
On the robust control of robot manipulators, IEEE Transactions on Automatic Control, vol.37, pp.1782-1786, 1992. ,
Improved robustness of multivariable Model Predictive Control under model uncertainties, 4th ICINCO, pp.283-288, 2007. ,
Control of a flexible arm by means of robustified MPC, pp.2229-2234, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00417678
Tracking control of flexible joint robots with uncertain parameters and disturbances, IEEE Transactions on Automatic Control, vol.39, issue.5, pp.1067-1072, 1994. ,
Modern Wiener-Hopf design of optimal controllerspart II : the multivariable case, IEEE Transactions on Automatic Control, vol.21, issue.3, pp.319-338, 1976. ,
