Accessible and Deterministic Automata: Enumeration and Boltzmann Samplers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2006
We present a bijection between the set $\mathcal{A}_n$ of deterministic and accessible automata with $n$ states on a $k$-letters alphabet and some diagrams, which can themselves be represented as partitions of the set $[\![ 1..(kn+1) ]\!]$ into $n$ non-empty parts. This combinatorial construction shows that the asymptotic order of the cardinality of $\mathcal{A}_n$ is related to the Stirling number $\{^{kn}_n\}$. Our bijective approach also yields an efficient random sampler of automata with $n$ states, of complexity $O(n^{3/2})$, using the framework of Boltzmann samplers.
dmAG0108.pdf (155.37 Ko) Télécharger le fichier
hal-00619870 , version 1 (03-10-2011)
hal-00619870 , version 2 (17-08-2015)
Frédérique Bassino, Cyril Nicaud. Accessible and Deterministic Automata: Enumeration and Boltzmann Samplers. Fourth Colloquium on Mathematics and Computer Science Algorithms, Trees, Combinatorics and Probabilities, 2006, Nancy, France. pp.151-160, ⟨10.46298/dmtcs.3499⟩. ⟨hal-00619870v2⟩
114 Consultations
1016 Téléchargements
