Sobolev stability of plane wave solutions to the cubic nonlinear Schrödinger equation on a torus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
It is shown that plane wave solutions to the cubic nonlinear Schrödinger equation on a torus behave orbitally stable under generic perturbations of the initial data that are small in a high-order Sobolev norm, over long times that extend to arbitrary negative powers of the smallness parameter. The perturbation stays small in the same Sobolev norm over such long times. The proof uses a Hamiltonian reduction and transformation and, alternatively, Birkhoff normal forms or modulated Fourier expansions in time.
nlspw-v19.pdf (200.14 Ko) Télécharger le fichier
hal-00622240 , version 1 (12-09-2011)
hal-00622240 , version 2 (11-10-2012)
Erwan Faou, Ludwig Gauckler, Christian Lubich. Sobolev stability of plane wave solutions to the cubic nonlinear Schrödinger equation on a torus. 2011. ⟨hal-00622240v1⟩
446 Consultations
987 Téléchargements
