Two-Scale Macro-Micro decomposition of the Vlasov equation with a strong magnetic field - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
In this paper, we build a Two-Scale Macro-Micro decomposition of the Vlasov equation with a strong magnetic field. This consists in writing the solution of this equation as a sum of two oscillating functions with circonscribed oscillations. The first of these functions has a shape which is close to the shape of the Two-Scale limit of the solution and the second one is a correction built to offset this imposed shape. The aim of such a decomposition is to be the starting point for the construction of Two-Scale Asymptotic-Preserving Schemes.
TSAPSVlas.pdf (308.91 Ko) Télécharger le fichier
hal-00638617 , version 1 (06-11-2011)
hal-00638617 , version 2 (08-11-2011)
hal-00638617 , version 3 (05-11-2012)
Nicolas Crouseilles, Emmanuel Frenod, Sever Adrian Hirstoaga, Alexandre Mouton. Two-Scale Macro-Micro decomposition of the Vlasov equation with a strong magnetic field. 2011. ⟨hal-00638617v2⟩
692 Consultations
313 Téléchargements
