Backstepping Fault Tolerant Control Based on Second Order Sliding Mode Observer : Application to Induction Motors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a fault tolerant control for induction motors based on backstepping strategy is designed. The proposed approach permits to compensate both the rotor resistance variations and the load torque disturbance. Moreover, to avoid the use of speed and flux sensors, a second order sliding mode observer is used to estimate the flux and the speed. The used observer converges in a finite time and permits to give a good estimate of flux and speed even in presence of rotor resistance variations and load torque disturbance. The stability of the closed loop system (controller + observer) is shown in two steps. First, the boundedness of the trajectories before the convergence of the observer is proved. Second, the trajectories convergence is proved after the convergence of the observer. The simulation results show the efficiency of the proposed control scheme.
Automatique
CDC_ND_MG_SD_JPB_final.pdf (126.89 Ko) Télécharger le fichier
hal-00639678 , version 1 (09-11-2011)
  • HAL Id : hal-00639678 , version 1
Nadia Djeghali, Malek Ghanes, Said Djennoune, Jean-Pierre Barbot. Backstepping Fault Tolerant Control Based on Second Order Sliding Mode Observer : Application to Induction Motors. IEEE CDC-ECC, Dec 2011, Orlando, United States. ⟨hal-00639678⟩
221 Consultations
541 Téléchargements
