Diagnostic of induction machines: A procedure for electrical fault detection and localisation, SDEMPED, 1999. ,
Diagnostic and fault tolerant control, 2003. ,
Sensorless control of induction machines with or without signal injection, IEEE Trans. Ind. Electron, 2006. ,
On Sensorless Induction Motor Drives: Sliding-Mode Observer and Output Feedback Controller, IEEE Transactions on Industrial Electronics, vol.56, issue.9, pp.3404-3413, 2009. ,
DOI : 10.1109/TIE.2009.2026387
URL : https://hal.archives-ouvertes.fr/inria-00531078
A robust sensorless output feedback controller of the induction motor drives: new design and experimental validation, International Journal of Control, vol.35, issue.1, 2010. ,
DOI : 10.1007/978-3-642-84379-2
URL : https://hal.archives-ouvertes.fr/inria-00450963
Sliding mode observers for fault detection and isolation, Automatica, vol.36, issue.4, pp.541-553, 2000. ,
DOI : 10.1016/S0005-1098(99)00177-6
Sensorless second order sliding mode observer for induction motor, 2010 IEEE International Conference on Control Applications, 1933. ,
DOI : 10.1109/CCA.2010.5611102
URL : https://hal.archives-ouvertes.fr/inria-00531067
Super twisting algorithm-based step-by-step sliding mode observers for nonlinear systems with unknown inputs, International Journal of Systems Science, vol.32, issue.10, 2007. ,
DOI : 10.1109/9.975511
URL : https://hal.archives-ouvertes.fr/inria-00128137
Makouf, A fault tolerant control architecture for induction motor drives in automotive applications, IEEE Trans. Veh. Technol, pp.1847-1855, 2004. ,
Fault tolerant control for induction motors using sliding mode observers, The 11th International Workshop On Variable Structure Systems, pp.190-196, 2010. ,
Implicit fault tolerant control: application to induction motors [12] A. Fekih, Effective fault tolerant control design for nonlinear systems: application to a class of motor control system, IET Control Theory Appl, Automatica, pp.355-371, 2004. ,
Commande des moteurs asynchrones 2, Optimisation , discrétisationdiscr´discrétisation et observateurs, Edition Hermes Science, 2000. ,
Backstepping control design and its applications to vehicle lateral control in automated highway systems, Dissertation, 1996. ,
A robust adaptive nonlinear control design, Proceedings of American Control Conference, pp.1365-1369, 1993. ,
DOI : 10.1016/0005-1098(95)00147-6
Fig. 1. Responses of the IM with rotor resistance variation of +50%Rr Fig. 2. Responses of the IM with rotor resistance variation of +100%Rr APPENDIX The induction motor used in this work is a 1.5KW , U = 220V , 50Hz, I n = 7.5A. The parameters are: R s = 1, 2002. ,
