Conference papers
Avoiding joint limits with a low-level fusion scheme
Olivier Kermorgant 1 F. Chaumette 1
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : Joint limits avoidance is a crucial issue in sensor- based control. In this paper we propose an avoidance strategy based on a low-level data fusion. The joint positions of a robot arm are considered as features that are continuously added to the control scheme when they approach the joint limits, and removed when the position is safe. We expose an optimal tuning of the avoidance scheme, ensuring the main task is disturbed as little as possible. We propose additional strategies to solve the particular cases of unsafe desired position and local minima. The control scheme is applied to the avoidance of joint limits while performing visual servoing. Both simulation and experimental results illustrate the validity of our approach.
keyword : Visual Servoing
Document type :
Conference papers
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-00639684
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Wednesday, November 9, 2011 - 5:22:29 PM
Last modification on : Thursday, January 20, 2022 - 4:20:28 PM
Long-term archiving on: : Thursday, November 15, 2012 - 11:36:16 AM
File
2011_iros_kermorgant2.pdf
Identifiers
  • HAL Id : hal-00639684, version 1
Citation
Olivier Kermorgant, F. Chaumette. Avoiding joint limits with a low-level fusion scheme. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'11, 2011, San Francisco, USA, United States. pp.768-773. ⟨hal-00639684⟩
Share
Metrics
Record views
181
Files downloads
197
