Distance-based and Orientation-based Visual Servoing from Three Points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Robotics Année : 2011
This paper is concerned with the use of a spherical-projection model for visual servoing from three points. We propose a new set of six features to control a 6-degree-of-freedom (DOF) robotic system with good decoupling properties. The first part of the set consists of three invariants to camera rotations. These invariants are built using the Cartesian distances between the spherical projections of the three points. The second part of the set corresponds to the angle-axis representation of a rotation matrix measured from the image of two points. Regarding the theoretical comparison with the classical perspective coordinates of points, the new set does not present more singularities. In addition, using the new set inside its nonsingular domain, a classical control law is proven to be optimal for pure rotational motions. The theoretical results and the robustness to points range errors of the new control scheme are validated through simulations and experiments on a 6-DOF robot arm.
Mots clés
2011_tro_tatsambon.pdf (1.22 Mo) Télécharger le fichier
hal-00639701 , version 1 (09-11-2011)
  • HAL Id : hal-00639701 , version 1
R. Tatsambon Fomena, O. Tahri, F. Chaumette. Distance-based and Orientation-based Visual Servoing from Three Points. IEEE Transactions on Robotics, 2011, 27 (2), pp.256-267. ⟨hal-00639701⟩
688 Consultations
356 Téléchargements
