Multitarget phd filtering: proposition of extensions to the multi-sensor case, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00501502
Multitarget-Multisensor Tracking: Applications and Advances (Volume III), chapter 3, 2000. ,
Multitarget tracking using the joint multitarget probability density, IEEE Transactions on Aerospace and Electronic Systems, vol.41, issue.4, pp.1396-1414, 2005. ,
DOI : 10.1109/TAES.2005.1561892
Handbook of Multisensor Data Fusion, chapter 14, 2002. ,
Multitarget bayes filtering via first-order multitarget moments, IEEE Transactions on Aerospace and Electronic Systems, vol.39, issue.4, pp.1152-1178, 2003. ,
DOI : 10.1109/TAES.2003.1261119
Sensor management with non-ideal sensor dynamics, Information Fusion Proceedings of the 7th International Conference on, 2004. ,
The multisensor PHD filter: I. General solution via multitarget calculus, Signal Processing, Sensor Fusion, and Target Recognition XVIII, 2009. ,
DOI : 10.1117/12.818024
The multisensor PHD filter: II. Erroneous solution via Poisson magic, Signal Processing, Sensor Fusion, and Target Recognition XVIII, 2009. ,
DOI : 10.1117/12.818025
Sequential monte carlo methods for multi-target filtering with random finite sets, IEEE Transactions on Aerospace and Electronic Systems, vol.41, issue.4, pp.1224-1245, 2005. ,
