A bi-criteria scheduling heuristic for distributed embedded systems under reliability and real-time constraints, International Conference on Dependable Systems and Networks, 2004, 2004. ,
DOI : 10.1109/DSN.2004.1311904
Fault-tolerance in the borealis distributed stream processing system, ACM Transactions on Database Systems, vol.33, issue.1, pp.1-44, 2008. ,
DOI : 10.1145/1331904.1331907
A Probabilistic Approach for Fault Tolerant Multiproc. Real-Time Scheduling, IPDPS, 2006. ,
Understanding Availability, IPTPS, 2003. ,
DOI : 10.1007/978-3-540-45172-3_24
chapter The Primary-Backup Approach, pp.199-216, 1993. ,
Performance and dependability of structured peer-to-peer overlays, International Conference on Dependable Systems and Networks, 2004, 2004. ,
DOI : 10.1109/DSN.2004.1311872
Query suspend and resume, Proceedings of the 2007 ACM SIGMOD international conference on Management of data , SIGMOD '07, 2007. ,
DOI : 10.1145/1247480.1247542
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.84.1241
Fault-tolerant scheduling on a hard real-time multiprocessor system, Proceedings of 8th International Parallel Processing Symposium, 1994. ,
DOI : 10.1109/IPPS.1994.288216
An Active Replication Scheme that Tolerates Failures in Dist. Embedded Real-Time Syst, DSN, 2003. ,
Effective Scheduling of Duplicated Tasks for Fault-Tolerance in Multiprocessor Systems, IEICE Trans. on Information and Systems, issue.3, p.85, 2002. ,
Replicated Process Alloc. for Load Distri. in Fault-Tolerant Multicomp, IEEE Computers, vol.46, issue.4, 1997. ,
The state of the art in distributed query processing, ACM Computing Surveys, vol.32, issue.4, pp.422-469, 2000. ,
DOI : 10.1145/371578.371598
A Comparative Study on Peer-to-Peer Failure Rate Estimation, ICPADS, 2007. ,
Query optimization in distributed networks of autonomous database systems, ACM Transactions on Database Systems, vol.31, issue.2, p.31, 2006. ,
DOI : 10.1145/1138394.1138397
A New Era of Performance Evaluation, Computer, vol.40, issue.9, 2007. ,
DOI : 10.1109/MC.2007.296
UNIT: User-centric Transaction Management in Web-Database Systems, ICDE, 2006. ,
Scaling Up Query Allocation in the Presence of Autonomous Participants, DASFAA, 2011. ,
DOI : 10.1007/978-3-642-20152-3_16
A Self-Adaptable Query Alloc. Framework for Dist, Inf. Syst. VLDBJ, issue.3, p.18, 2009. ,
Dynamic Multi-Resource Load Balancing in Parallel DB Syst, VLDB, 1995. ,
Practical Load Balancing for Content Req, P2P Networks. Distributed Computing, 2006. ,
Measuring and analyzing the characteristics of Napster and Gnutella hosts, Multimedia Systems, vol.9, issue.2, pp.170-184, 2003. ,
DOI : 10.1007/s00530-003-0088-1
Distributed Systems, chapter Replication Management Using the State-Machine Approach, pp.169-197, 1993. ,
Query Processing Over Incomplete Autonomous Databases, VLDB, 2007. ,
The Costs and Limits of Availability for Replicated Services, SOSP, 2001. ,
