Automatic generation of discrete handlers of real-time continuous control tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a novel technique for designing discrete, logical control loops, on top of continuous control tasks, ensuring logical safety properties of the tasks sequencings and mode changes. We define this new handler on top of the real-time executives built with the ORCCAD design environment for control systems, which is applied, e.g. to robotics and real-time networked control. It features structures of control tasks, each equipped with a local automaton, used for the reactive, event-based management of its activity and modes. The additional discrete handler manages the interactions between tasks, concerning, e.g., mutual exclusions, forbidden or imposed sequences. We use a new reactive programming language, with constructs for finite-state machines and data-flow nodes, and a mechanism of behavioral contracts, which involves discrete controller synthesis. The result is a discrete control loop, on top of the continuous control loops, all integrated in a coherent real-time architecture. Our approach is illustrated and validated experimentally with the case study of a robot arm.
Automatique
bzrccad.pdf (131.88 Ko) Télécharger le fichier
hal-00640406 , version 1 (11-11-2011)
  • HAL Id : hal-00640406 , version 1
Ahmed Soufyane Aboubekr, Gwenaël Delaval, Roger Pissard-Gibollet, Eric Rutten, Daniel Simon. Automatic generation of discrete handlers of real-time continuous control tasks. IFAC WC 2011 - 18th IFAC World Congress, Aug 2011, Milan, Italy. ⟨hal-00640406⟩
284 Consultations
349 Téléchargements
