Fitting genetic algorithms to distributed online evolution of network protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Networks Année : 2010
In this work, we introduce a framework for enabling the on-line evolution of network protocols. The proposed approach is based on the use of techniques and tools drawn from evolutionary computing research, and it enables embedding evolutionary features in the operation of network protocols. In this way, it becomes possible to build a system in which the operation of the network changes at run-time to adapt to the current conditions. As a case study, we apply the proposed framework to the evolution of forwarding schemes in intermittently connected wireless networks. Simulation results are reported to validate the ability of the proposed scheme to converge to the optimal operating point and to explore the various trade-offs deriving from its design and implementation.
comnet-author.pdf (961.88 Ko) Télécharger le fichier
hal-00640798 , version 1 (11-07-2019)
Sara Alouf, Giovanni Neglia, Iacopo Carreras, Daniele Miorandi, Álvaro Fialho. Fitting genetic algorithms to distributed online evolution of network protocols. Computer Networks, 2010, 54 (18), pp.3402-3420. ⟨10.1016/j.comnet.2010.06.015⟩. ⟨hal-00640798⟩
Collections
INRIA INRIA2
184 Consultations
168 Téléchargements
