Computing the least common subsumer wrt a background terminology, Journal of Applied Logic, vol.5, issue.3, pp.392-420, 2007. ,
Mathematical Morphology, Handbook of Spatial Logics, chapter 13, pp.857-947, 2007. ,
Explanatory Relations based on Mathematical Morphology, pp.736-747, 2001. ,
A case for abductive reasoning over ontologies, OWL : Experiences and Directions, 2006. ,
Formal concept analysis, 1999. ,
The Algebraic Basis of Mathematical Morphology ? Part I : Dilations and Erosions, Computer Vision, Graphics and Image Processing, vol.50, pp.245-295, 1990. ,
Fuzzy spatial relation ontology for image interpretation . Fuzzy Sets and Systems, pp.1929-1951, 2008. ,
Integrating bipolar fuzzy mathematical morphology in description logics for spatial reasoning, European Conference on Artificial Intelligence ECAI 2010, pp.497-502, 2010. ,
ABox Abduction in the Description Logic, Journal of Automated Reasoning, vol.46, issue.1, pp.43-80, 2011. ,
Ontology-based reasoning techniques for multimedia interpretation and retrieval, Semantic Multimedia and Ontologies, pp.55-98, 2008. ,
Jumping to Explanations versus jumping to Conclusions, Artificial Intelligence, vol.111, pp.131-169, 1999. ,
The Algebraic Basis of Mathematical Morphology ? Part II : Openings and Closings, Computer Vision, Graphics and Image Processing, vol.54, pp.74-97, 1991. ,
TAAABLE : Text Mining, Ontology Engineering , and Hierarchical Classification for Textual Case-Based Cooking, ECCBR Workshops, Workshop of the First Computer Cooking Contest, pp.219-228, 2008. ,
Représentation et raisonnement sur les intervalles cycliques, Journées nationales sur les modèles de raisonnement, 1999. ,
TAAABLE 3 : adaptation of ingredient quantities and of textual preparations, Proceedings of the Eighteenth International Conference on Case-Based Reasoning, pp.189-198, 2010. ,
Conservative adaptation in metric spaces, Advances in Case-Based Reasoning, pp.135-149, 2008. ,
Merging qualitative constraints networks defined on different qualitative formalisms, Conference on Spatial Information Theory (COSIT'09), 2009. ,
Temporal constraint networks, Artificial Intelligence, vol.49, pp.61-95, 1991. ,
Question answering based on temporal inference, Proceedings of the AAAI-2005 Workshop on Inference for Textual Question Answering, 2005. ,
Integrating metric and qualitative temporal reasoning, Proceedings of the 9th National Conference of the American Association for Artificial Intelligence (AAAI), pp.241-246, 1991. ,
Utilisation d'une algèbre temporelle pour la représentation et l'adaptation de recettes de cuisine, Actes du 17e atelier de raisonnement à partir de cas, 2009. ,
Représentation temporelle qualitative de recettes de cuisine, Cinquième atelier « Représentation et raisonnement sur le temps et l'espace, pp.25-28, 2010. ,
Adaptation of cooking instructions following the workflow paradigm, Proceedings of the Eighteenth International Conference on Case-Based Reasoning, pp.199-208, 2010. ,
comporte 47 verbes de déplacement en nous appuyant sur les travaux précités et 50 verbes de perception. D'autre part, la base lexicale des indirections est construite afin de correspondre à au moins une des relations spatiales spécifiées dans les travaux de Afin de valider les groupes de noms propres comme les noms toponymiques, Nous avons construit une base lexicale des verbes qui, 1991. ,
C'est la sémantique du token qui détermine la transformation de l'état du transducteur. Par exemple, la polarité du verbe de déplacement "descendre" fait passer le transducteur de l'état 0 à l'état 7. Ensuite c'est la polarité de la préposition associée au verbe (selon Laur (1991)) qui détermine le passage à l'état 8. Enfin, lorsque le parcours du Toponyme "territoire aride au sud de la région d'Aragon" est terminé, le transducteur 2. Hearst a proposés des patterns lexico-syntaxiques pour l'extraction des termes hyponymiques 3. Institut géographique national Planning as temporal reasoning, pp.3-14, 1991. ,
Le raisonnement spatial Le temps, l'espace et l'évolutif en sciences du traitement de l'information, pp.33-53, 2000. ,
Navigation et appariement d'objets géographiques dans une ontologie, EGC '07, pp.391-396, 2007. ,
Building a geographical ontology for intelligent spatial search on the web, IASTED International Conference on Databases and Applications, 2005. ,
Sxpipe2 : architecture pour le traitement présyntaxique de corpus bruts, TAL, vol.49, issue.2, pp.155-188, 2008. ,
