Optimal Control of Sleep Periods for Wireless Terminals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Journal on Selected Areas in Communications Année : 2011
We consider a mobile connected to a base station, and study how to optimally schedule shutting off its transceiver. First, we study the model from optimal control perspective. We consider off-times (periods of inactivity) of (controlled) duration. We study the question of scheduling "waking up" instants in which the mobile communicates with the base station and checks whether the inactivity period is over. There is a cost proportional to the delay from the moment the off-time ends until the mobile discovers it, a (small) running cost while the mobile is sleeping and a cost for waking up. We present conditions for optimal sleep periods to be constant and derive the optimal period. For the case that the conditions do not hold, we obtain suboptimal solutions which perform strictly better than the optimal constant one. We then investigate optimality restricted to classes of policies with specific constraints. We adopt the parametric optimization approach which entails cost minimization for a given parameterized policy and selection of the best policy among a class. We then compare the performance of optimal policies, of the proposed suboptimal policies as well as that of standard policies like IEEE 802.16e.
jsacEE142-author-version.pdf (309.86 Ko) Télécharger le fichier
hal-00640926 , version 1 (05-07-2019)
Amar Prakash Azad, Sara Alouf, Eitan Altman, Vivek Borkar, Georgios Paschos. Optimal Control of Sleep Periods for Wireless Terminals. IEEE Journal on Selected Areas in Communications, 2011, Energy-Efficient Wireless Communications, 29 (8), pp.1605-1617. ⟨10.1109/JSAC.2011.110910⟩. ⟨hal-00640926⟩
Collections
INRIA INRIA2
106 Consultations
93 Téléchargements
