Performance analysis of peer-to-peer storage systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper evaluates the performance of two schemes for recovering lost data in a peer-to-peer (P2P) storage systems. The first scheme is centralized and relies on a server that recovers multiple losses at once, whereas the second one is distributed. By representing the state of each scheme by an absorbing Markov chain, we are able to compute their performance in terms of the delivered data lifetime and data availability. Numerical computations are provided to better illustrate the impact of each system parameter on the performance. Depending on the context considered, we provide guidelines on how to tune the system parameters in order to provide a desired data lifetime.
itc20-author.pdf (232.46 Ko) Télécharger le fichier
hal-00641279 , version 1 (11-07-2019)
Sara Alouf, Abdulhalim Dandoush, Philippe Nain. Performance analysis of peer-to-peer storage systems. 20th international teletraffic conference on Managing traffic performance in converged networks (ITC '07), Jun 2007, Ottawa, Canada. pp.642-653, ⟨10.1007/978-3-540-72990-7_57⟩. ⟨hal-00641279⟩
Collections
INRIA INRIA2
103 Consultations
76 Téléchargements
