Web Services Verification and Prudent Implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alice&Bob notation is widely used to describe conversations between partners in security protocols. We present a tool that compiles an Alice&Bob description of a Web Services choreography into a set of servlets. For that we first compute for each partner an executable specification as prudent as possible of her role in the choreography. This specification is expressed in ASLan language, a formal language designed for modeling Web Services tied with security policies. Then we can check with automatic tools that this ASLan specification verifies some required security properties such as secrecy and authentication. If no flaw is found, we compile the specification into Java servlets that real partners can use to execute the choreography.
setop2011_submission_22.pdf (317.51 Ko) Télécharger le fichier
hal-00641326 , version 1 (15-11-2011)
  • HAL Id : hal-00641326 , version 1
Tigran Avanesov, Yannick Chevalier, Mohammed Anis Mekki, Michael Rusinowitch. Web Services Verification and Prudent Implementation. 4th SETOP International Workshop on Autonomous and Spontaneous Security, Sep 2011, Leuven, Belgium. ⟨hal-00641326⟩
300 Consultations
202 Téléchargements
