New interface
Patents
Flow Aware Congestion Avoidance Method and System
Abstract : A method for packet flow-rate control within a network node (4) comprised within a packet-switched communication network connection linking a sender (1) to a receiver (2), the said method comprising the following steps - computing the average arrival rate of packets since the last packet mark or drop event; - sending a congestion signal to the sender as soon as the computed packet arrival rate is above a predefined target rate; - repeating congestion signal sending until the sender receives at least a congestion signal and consequently reduces the sending rate.
Complete list of metadata
https://hal.inria.fr/hal-00641420
Contributor : Sara Alouf Connect in order to contact the contributor
Submitted on : Tuesday, November 15, 2011 - 5:01:44 PM
Last modification on : Thursday, January 20, 2022 - 4:12:22 PM
Identifiers
  • HAL Id : hal-00641420, version 1
Collections
Citation
Alberto Blanc, Sara Alouf, Konstantin Avrachenkov, Georg Post. Flow Aware Congestion Avoidance Method and System. France, Patent n° : EP2413542. 2010. ⟨hal-00641420⟩
Share
Metrics
Record views
102
