On the Complexity of Computing the Profinite Closure of a Rational Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2011
The profinite topology is used in rational languages classification. In particular, several important decidability problems, related to the Malcev product, reduce to the computation of the closure of a rational language in the profinite topology. It is known that given a rational language by a deterministic automaton, computing a deterministic automaton accepting its profinite closure can be done with an exponential upper bound. This paper is dedicated the study of a lower bound for this problem: we prove that in some cases, if the alphabet contains at least three letters, it requires an exponential time.
PROBINFheam.pdf (118.63 Ko) Télécharger le fichier
hal-00641554 , version 1 (16-11-2011)
Pierre-Cyrille Heam. On the Complexity of Computing the Profinite Closure of a Rational Language. Theoretical Computer Science, 2011, 412 (41), pp.5808-5813. ⟨10.1016/j.tcs.2011.06.022⟩. ⟨hal-00641554⟩
113 Consultations
181 Téléchargements
