Linear Diophantine Equations Over Polynomials and Soft Decoding of Reed???Solomon Codes, IEEE Transactions on Information Theory, vol.51, issue.7, pp.2257-2265, 2005. ,
DOI : 10.1109/TIT.2005.850097
Improved list decoding of generalized reed-solomon and alternant codes over rings, International Symposium onInformation Theory, 2004. ISIT 2004. Proceedings., p.384, 2004. ,
DOI : 10.1109/ISIT.2004.1365421
List Decoding of Generalized Reed???Solomon Codes Over Commutative Rings, IEEE Transactions on Information Theory, vol.51, issue.1, pp.411-419, 2005. ,
DOI : 10.1109/TIT.2004.839546
List-decoding of binary Goppa codes up to the binary Johnson bound, 2011 IEEE Information Theory Workshop, pp.229-233, 2011. ,
DOI : 10.1109/ITW.2011.6089384
URL : https://hal.archives-ouvertes.fr/inria-00547106
On the Roth and Ruckenstein equations for the Guruswami-Sudan algorithm, 2008 IEEE International Symposium on Information Theory, pp.2620-2624, 2008. ,
DOI : 10.1109/ISIT.2008.4595466
URL : https://hal.archives-ouvertes.fr/inria-00509209
Decoding algorithms for algebraic geometric codes over rings, 2006. ,
Algebraic coding theory. M-6, 1984. ,
Error correction for algebraic block codes, 1986. ,
Relaxed algorithms for p-adic numbers, Journal de Th??orie des Nombres de Bordeaux, vol.23, issue.3, 2011. ,
DOI : 10.5802/jtnb.777
URL : https://hal.archives-ouvertes.fr/hal-00486680
Polynomial and matrix computations Fundamental algorithms, Progress in Theoretical Computer Science. Birkhäuser, 1994. ,
Polynomial evaluation and interpolation on special sets of points, Journal of Complexity, vol.21, issue.4, pp.420-446, 2005. ,
DOI : 10.1016/j.jco.2004.09.009
On fast multiplication of polynomials over arbitrary algebras, Acta Informatica, vol.7, issue.7, pp.693-701, 1991. ,
DOI : 10.1007/BF01178683
On expansion of algebraic functions in power and Puiseux series, I, Journal of Complexity, vol.2, issue.4, pp.271-294, 1986. ,
DOI : 10.1016/0885-064X(86)90006-3
On expansion of algebraic functions in power and Puiseux series, II, Journal of Complexity, vol.3, issue.1, pp.1-25, 1987. ,
DOI : 10.1016/0885-064X(87)90002-1
On the structure and ideal theory of complete local rings, Transactions of the American Mathematical Society, vol.59, issue.1, pp.54-106, 1946. ,
DOI : 10.1090/S0002-9947-1946-0016094-3
Rational Puiseux expansions, Compositio Math, vol.70, issue.2, pp.119-154, 1989. ,
Effective Procedures in Field Theory, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.248, issue.950, pp.407-432, 1956. ,
DOI : 10.1098/rsta.1956.0003
Faster integer multiplication, Proceedings of the Thirty-Ninth ACM Symposium on Theory of Computing, pp.57-66, 2007. ,
A New Algorithm for Decoding Reed-Solomon Codes, Communications, Information and Network Security, pp.55-68, 2003. ,
DOI : 10.1007/978-1-4757-3789-9_5
Computing roots of polynomials over function fields of curves Coding theory and cryptography: from enigma and Geheimschreiber to quantum theory, pp.214-228, 2000. ,
Hensel and Newton methods in valuation rings, Mathematics of Computation, vol.42, issue.166, pp.637-661, 1984. ,
DOI : 10.1090/S0025-5718-1984-0736459-9
Modern computer algebra, second edn, 2003. ,
MPFQ, a finite field library, 2008. ,
GMP, the GNU multiple precision arithmetic library, 1991. ,
Series Expansions of Algebraic Functions, Computational Algebra and Number Theory, Mathematics and Its Applications, pp.267-277, 1995. ,
DOI : 10.1007/978-94-017-1108-1_19
Improved decoding of Reed-Solomon and algebraic-geometric codes, Proceedings 39th Annual Symposium on Foundations of Computer Science (Cat. No.98CB36280), pp.1757-1767, 1998. ,
DOI : 10.1109/SFCS.1998.743426
Computing Local Integral Closures, Journal of Symbolic Computation, vol.32, issue.3, pp.211-230, 2001. ,
DOI : 10.1006/jsco.2001.0447
Complexity of computation of embedded resolution of algebraic curves, Proceedings of Eurocal 87, pp.381-390, 1987. ,
DOI : 10.1007/3-540-51517-8_143
Extension of expansion base algorithm for multivariate analytic factorization including the case of singular leading coefficient, ACM SIGSAM Bulletin, vol.39, issue.4, pp.122-126, 2005. ,
DOI : 10.1145/1140378.1140383
The algebraic closure of the power series field in positive characteristic, Proc. Amer, pp.3461-3470, 2001. ,
On algebraic decoding of algebraic-geometric and cycling codes, 1996. ,
Algebraic soft-decision decoding of reed-solomon codes, IEEE Transactions on Information Theory, vol.49, issue.11, pp.2809-2825, 2003. ,
DOI : 10.1109/TIT.2003.819332
Generalized Newton-Puiseux theory and Hensel's lemma in ${f C}[![x,y]!]$, Journal canadien de math??matiques, vol.41, issue.6, pp.1101-1116, 1989. ,
DOI : 10.4153/CJM-1989-048-7
Fast separable factorization and applications, Applicable Algebra in Engineering, Communication and Computing, vol.102, issue.1, pp.135-160, 2008. ,
DOI : 10.1007/s00200-008-0062-4
URL : https://hal.archives-ouvertes.fr/hal-00681420
Error correction coding: mathematical methods and algorithms, 2005. ,
DOI : 10.1002/0471739219
Complexity bounds for the rational Newton-Puiseux algorithm over finite fields, Applicable Algebra in Engineering, Communication and Computing, vol.69, issue.1???2, pp.187-217, 2011. ,
DOI : 10.1007/s00200-011-0144-6
URL : https://hal.archives-ouvertes.fr/hal-00601438
Finite associative rings, Compositio Math, vol.21, pp.195-229, 1969. ,
Decoding Reed-Solomon Codes Beyond Half the Minimum Distance, Coding Theory, Cryptography and Related Areas, pp.221-236, 2000. ,
DOI : 10.1007/978-3-642-57189-3_20
Efficient decoding of Reed-Solomon codes beyond half the minimum distance, Proceedings. 1998 IEEE International Symposium on Information Theory (Cat. No.98CH36252), p.56, 1998. ,
DOI : 10.1109/ISIT.1998.708637
Fast multiplication of large numbers, Computing, vol.150, issue.3-4, pp.281-292, 1971. ,
DOI : 10.1007/BF02242355
Decoding of Reed Solomon Codes beyond the Error-Correction Bound, Journal of Complexity, vol.13, issue.1, pp.180-193, 1997. ,
DOI : 10.1006/jcom.1997.0439
Simplified procedure for correcting both errors and erasures of Reed-Solomon code using Euclidean algorithm, IEE Proceedings E Computers and Digital Techniques, vol.135, issue.6, pp.318-324, 1988. ,
DOI : 10.1049/ip-e.1988.0043
Algebraic geometric codes over rings, Journal of Pure and Applied Algebra, vol.144, issue.1, pp.91-110, 1999. ,
DOI : 10.1016/S0022-4049(98)00047-4
Algebraic curves Reprint of the 1950 edition 47 On the complexity of rational Puiseux expansions, Pacific J. Math, vol.188, issue.2, pp.369-387, 1978. ,
A polynomial-time complexity bound for the computation of the singular part of a Puiseux expansion of an algebraic function, Mathematics of Computation, vol.69, issue.231, pp.1167-1182, 2000. ,
DOI : 10.1090/S0025-5718-00-01246-1
