On a Conjecture about Binary Strings Distribution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
It is a difficult challenge to find Boolean functions used in stream ciphers achieving all of the necessary criteria and the research of such functions has taken a significant delay with respect to cryptanalyses. Very recently, an infinite class of Boolean functions has been proposed by Tu and Deng having many good cryptographic properties under the assumption that the following combinatorial conjecture about binary strings is true: Conjecture 0.1. Let S t , k be the following set: $$ S_t,k= \left\(a,b) \in \left( \mathbb Z / (2^k-1) \mathbb Z \right)^2 | a + b = t ~\rm and ~ w(a) + w(b) Then: $$ |S_t,k| \leq 2^k-1. $$ The main contribution of the present paper is the reformulation of the problem in terms of carries which gives more insight on it than simple counting arguments. Successful applications of our tools include explicit formulas of for numbers whose binary expansion is made of one block, a proof that the conjecture is asymptotically true and a proof that a family of numbers (whose binary expansion has a high number of 1 s and isolated 0 s) reaches the bound of the conjecture. We also conjecture that the numbers in that family are the only ones reaching the bound.
hal-00642283 , version 1 (17-11-2011)
Jean-Pierre Flori, Hugues Randriambololona, Gérard Cohen, Sihem Mesnager. On a Conjecture about Binary Strings Distribution. Carlet, Claude and Pott, Alexander. Sequences and Their Applications - SETA 2010, 6338, Springer Berlin / Heidelberg, pp.346-358, 2010, 978-3-642-15873-5. ⟨10.1007/978-3-642-15874-2_30⟩. ⟨hal-00642283⟩
151 Consultations
0 Téléchargements
